black goo in turbo compressor??????
Old Mar 12, 2010 | 07:07 PM
faylorz's Avatar
A buddy of mine has a he351ve and we took the compressor housing off to inspect it and its covered in a film of like sticky black goo. Its almost like rubberized undercoating all over the compressor housing and compressor wheel. what could this be?
Old Mar 12, 2010 | 07:41 PM
dzl_damon's Avatar
IDK if the newer Cummins have an EGR, or where it re-enters, but EGR can REALLY goo up an intake in a diesel for sure. Seen it in my old Mercedes and many TDI's.
Maybe they suck the crankcase vent into the inlet? Or a seal was leaking oil into the compressor and it goo'd up with the heat of compression.
Old Mar 12, 2010 | 07:43 PM
Richie O's Avatar
366 Spring Chicken
Does he have a oil covered filter like a K+N air filter?
Old Mar 12, 2010 | 08:07 PM
SmokemS's Avatar
i had that same "goo" in my i/c pipe well on inside of the rubber boot
Old Mar 12, 2010 | 09:34 PM
PapeCAT's Avatar
Turbo seals leaking oil onto the compressor/intake?
Old Mar 12, 2010 | 09:47 PM
DNRCustoms's Avatar
X2!!
Old Mar 13, 2010 | 01:05 AM
grail4life's Avatar
hey ill get pics up tomorrow of it. its only on the the compressor housing and wheel. dry not really goo.... scrapes off pretty easy.....
Old Mar 13, 2010 | 01:06 AM
grail4life's Avatar
its not in the intake tubes or anything
Old Mar 13, 2010 | 07:39 PM
Boatnik's Avatar
It probably won't be in the intake tube. It takes pressure to make pressure. Typically drive pressure is higher than boost. If there is an oil seal leak it could travel to the compressor side and goo up the works. However after saying that I would think that the deposit on the compressor wheel woud be wet oil and carbon.
Mike L
Jul 2, 2010 10:06 AM
faylorz
Mar 13, 2010 10:19 AM
DNRCustoms
Off Road / 4x4
Feb 7, 2010 09:18 PM
barryp
Oct 25, 2007 06:07 PM
FastSS
Apr 15, 2006 11:53 PM
