BHAF install - Some quick questions
Old Sep 10, 2006 | 07:27 PM
cootz's Avatar
So I attempted to install the BHAF the other day, but I thought before I finish the job I better ask some questions. I fab'd the Ol' Smokey Mount to house the BHAF.
1) Space is limited, so when you remove the stock air box, do you also remove the bracket on the wheel well that holds your stock air box in place? And do you also remove the air "duct" from underneath the headlight that directs flow into your stock air box, or will this help with air flow on the BHAF?
2) Getting that Ol' Smokey Mount in there isn't all that fun, am I going to have to remove and install this mount every air filter change?
3) Can I use the stock intake air setup? I see a number of ppl installing a new setup with exhaust tubing etc...but is this necessary?
4) Am am planning on putting 4" exhaust in the near future, but is this much air flow okay with my stock 3", or will my EGT's be too high?
Alot of little questions, but thanks in advance.
Old Sep 10, 2006 | 07:30 PM
ouchman's Avatar
I don't have the answers to all your questions, but if you want a good alternative to the Old Smokey mount, check my sig and my pics. This one works great and is EASY access.
Old Sep 10, 2006 | 07:32 PM
1) I didn't find removing the bracket to be necessary. The duct couldn't hurt.
2) Yes. Pain in the butt, isn't it? On the upside, if you drive an average amount you only need to do it every couple of years.
3)The stock tubing is not a good fit and it pops off a lot. Aggravating and bad for the motor.
4)More air can only improve EGT.
Old Sep 10, 2006 | 09:40 PM
BC847's Avatar
1st Generation Admin
AH HAAAH!! That's the alternate mount I was looking, . . . . . . off to edit a thread.
Rickcher
Sep 2, 2009 05:08 PM
kenny1987
Feb 3, 2008 12:43 PM
Ace
Oct 31, 2007 06:46 PM
cluckmaster
Aug 12, 2006 07:24 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
