best place to find injectors
Old Jun 7, 2006 | 07:58 PM
sleeping dodge's Avatar
would like to find around 115 horse increase injectors best place to get them and best make thanks
Old Jun 7, 2006 | 08:18 PM
G1625S's Avatar
Make, model and year of your rig? We need details, man, details! Go to the user cp at the top-ish left of the screen and fill out your signature. If you have a 1st gen, you're gonna spend some BIG bucks getting a 115 horse injector, and you'd better have the turbo(s) to back all that #2 up!
edit:Welcome to DTR!
Old Jun 7, 2006 | 08:20 PM
JD730's Avatar
That sounds like custom EDM territory. Bill Gilbert has a set in one of his trucks. Schieds makes custom EDM's you only need to know what you want, hole size, how many holes, and spray angles, etc.
Old Jun 7, 2006 | 08:31 PM
spunbearing's Avatar
I like PDR myself. They sell them only in matched sets. The tolerances of injectors could be off by as much as 5% and most companies sell them and say good enough. Piers takes the time to match them.
Old Jun 7, 2006 | 08:34 PM
its 92 250 4+4 and what would i need for turbo were could get that and a phone number so can get info about the stuff i need thanks
Old Jun 7, 2006 | 09:45 PM
flashgordon's Avatar
So why is 115 horse inj your goal? what are you trying to do with this truck? tractor Puller,haller, street toy, and has this truck been modify yet? sorry but must have more info!!!!!
ps will get you headed in the right deredtion....we just need to now what that is.
Old Jun 8, 2006 | 09:37 AM
timb's Avatar
DDP stage 4's. HTT Phat shaft 62/14 to take care of the fuel. And at that point you need an o-ringed head and studs. Oh ya. forgot about the 4" exhaust. And the tranny. { oops,} Then the gov. spring, pump timing, intake. Man my wallet is starting to hurt thinking about all of this.
Old Jun 8, 2006 | 06:14 PM
i would like to pull this truck little at local fairs nothing real huge i just got the truck and ive seen at local fairs and of course cummings is always winning but there not stock but still are driving them and pulling trailers far as normal buisness use its got three inch ex kn air filter timing advanced a little star wheel on fuel pump all the way in fuel screw i got to get metric tap to rethread and also have put a shift kit in the tranny and now i want some injectors not even that big maybe 100hp or so think maybe get me started with this info would appreciate it thanks
Old Jun 8, 2006 | 08:27 PM
smoky beast's Avatar
those numbers are pretty high for 1st gen, i would go with piers diesel pod injectors, they add 70 hp
Old Jun 8, 2006 | 08:30 PM
Just changing injectors isn't going to get you 110 extra HP. If you install POD injectors, HTT stage 2 or stage 3 turbo kit, do some pump mods and a 3200 gsk, and install a 4 inch exhaust you should be about where you want to be.
Old Jun 9, 2006 | 05:51 PM
ok where would u look for this stuff i can get the 4in ex but the other dont know where to even look and in a ruff figure what do u think it would cost
lovin1stgens
Nov 24, 2010 06:01 PM
Biggator
Sep 24, 2008 07:58 AM
Sniper05
May 24, 2008 09:03 PM
5.9Excursion
Nov 21, 2007 06:50 PM
