Battery wont hold a charge
My batt wont hold a charge just replaced alternator and now i think its the regulator but i was told that my truck is run by a computer and not a reg. i thought the guy was wrong so i wanted to ask u guys.
With the engine running the center portion of the a/c clutch rotates with the pulley when it is engaged. You should also see fluid going by the sight glass on the dryer. I don't know on the sensor.
Check to make sure the A/C clutch will kick in. This sounds like a bad crank sensor or a problem with the wiring for it.
How does one Troubleshoot it and a Fusible link ??
