Bad or worn out Redhead steering box?
My brothers 92 W250 has redhead power steering box installed but steering is really loose and has shimmy going down the road. We've tried adjusting it but it would tighten up to point where steering wheel would be hard to turn but there's still slop in steering. Ive taken video of me twisting steering shaft and there's nothing happening at the other end of steering gear. Is this bad box that needs to be rebuilt?
https://www.youtube.com/watch?v=bokq...ature=youtu.be |
Originally Posted by Silver R/T
(Post 3351648)
Looks like the box has developed a bit of a dead spot in the middle. My recently installed 'good used' box is about the same.
Most likely need to increase your caster angle to get rid of the shimmy and prolong box life. |
I have never seen good things come from adjusting a box like that on a truck.
So you're saying box is worn out and needs replaced?
(Post 3351675)
Take a video with the truck running and do that by hand. If you move it... it should send power to the output and that will give you a rough idea if it's worn. If you adjusted it, though, you will mess up the turns on the steering wheel and you will not get sensitivity because from redhead they're at top center.
The steering shaft play is pretty normal, I bet the steering wheel is moving as well :P I can't remember the ratio on those gearboxes, 18:1 seems right but I don't remember. |
(Post 3351665)
Call redhead and tell them whats happening. Pretty sure they have a lifetime guarantee on their box rebuilds.... At least until someone messes with the preload adjustment |
