93 D250 mileage has dropped. New to diesels
Old 08-13-2018, 10:41 AM
Chevjerico's Avatar
Hey guys, I've had my truck for three years now. I must confess I haven't learned as much as I should of by now. I am a gear head, but the Harley's and building big block Chevy's takes most of my mental capacity. I did purchase about 50 lbs of OE manuals to read. Everything I could find on my truck.
My mileage has dropped. I see more smoke at start up then before. My truck was hopped up by the previous owner, and I believe it to be a moderate amount. It was well taken care of. 3200 govenor spring, upgraded turbo(older Banks stuff), nothing crazy, fuel screw adjustment, and Pac brake.
​​​​​​​Any ideas where to start? Anything obvious? Recomended service?
Old 08-13-2018, 10:47 AM
AlpineRAM's Avatar
I asked a mod to move it to first gen trucks.
I would start by checking for air in fuel, (this leads to lazy injection, bad running and bad mileage), then change fuel filter and air filter.
If that does not help- pop-check the injectors.
Old 08-13-2018, 11:04 AM
Chevjerico's Avatar
I already changed fuel filter and air filter. It runs fine. I can't tell any difference. I wonder if the fuel screw came loose and moved in the wrong direction? I'll search the forums for what pop check means.
Old 08-13-2018, 11:43 AM
John_P's Avatar
Hey AlpineRAM,.....thanks for the message to move this to the 1st Gen Section!
Old 08-13-2018, 06:14 PM
Received 1,332 Likes on 862 Posts
What kind of mileage on the motor? Could be tired injectors, and “pop test” basically means the company puts the injector in a machine and load it with fuel pressure and they record when the injector “pops” and allows the fuel to be released from the injector.
Old 08-13-2018, 06:52 PM
Chevjerico's Avatar
I believe fairly new injectors 3-5 years old. Bosh 194 is what the previous owner told me. Truck is low miles and pretty clean 170k, maybe I'll have to take to the shop.
Old 08-14-2018, 10:56 AM
Try disconnecting the KSB power wire, if the AIT sensor has gone bad then the ksb could be on all the time and you will have too much advance timing and you could loose a bit of power and mileage.
Old 08-14-2018, 11:02 AM
Chevjerico's Avatar
Try disconnecting the KSB power wire, if the AIT sensor has gone bad then the lab could be on all the time and you will have too much advance timing and you could loose a bit of power and mileage.
Cool, I'll give it a shot.
rockhound
01-06-2012 12:38 PM
West Coast
10-02-2011 11:51 PM
04ctd
07-05-2008 10:13 AM
Bearwhiz
12-04-2006 07:41 AM
TxDiesel007
07-17-2005 05:03 PM
Quick Reply: 93 D250 mileage has dropped. New to diesels
