Autometer 2888 tach
Old Apr 18, 2008 | 09:43 PM
Montana2x2's Avatar
Autometer 2888 tach
Has anyone had problems with their autometer tach that has the probe on the alternator? Mine was working fine then the needle started to deflect and at times just goes to zero and stays there for a while. I marked the probe when I got it to a good spot on the alternator and it has not moved. I checked all conections, grounds, fuses etc. Any suggestions? Thanks.
Old Apr 18, 2008 | 11:15 PM
Alwaysworking's Avatar
alwaysonDTR
no problems with mine yet. does it do it when you push the breaks or the turn on the turn signals?
Old Apr 19, 2008 | 01:22 AM
stackx2's Avatar
mine did that and i found a short in a wire
Old Apr 19, 2008 | 04:59 AM
Mine's gone wacky like that, I just haven't found the time to diagnose it yet.
Old Apr 19, 2008 | 07:43 AM
Montana2x2's Avatar
When it first started acting up it would vibrate in time with the turn signal. I never noticed it with the brakes. Now it moves around all the time.
Old Apr 19, 2008 | 07:44 AM
Montana2x2's Avatar
Was it one of the probe wires?
Old Apr 19, 2008 | 12:37 PM
alwaysonDTR
switch to a different power source,not connected to the turn sigal or break lights, i taped off the back side of the fuse block and added a seperate fuse.
just a thought.
Old Apr 19, 2008 | 02:37 PM
Montana2x2's Avatar
just a thought.
I used the fuse for the cruise control which was unused in my truck. I'll run a hot wire direct from the battery and see if that helps. If it does I'll pull power right off the ignition switch. Thanks
Old Apr 20, 2008 | 12:38 PM
Montana2x2's Avatar
I ran the hot and ground right to the battery and still no change. I guess I'll call Autometer and see if they can give me any help.
Old Apr 20, 2008 | 12:52 PM
alwaysonDTR
did you try moving the prob to a different spot? like 1/2 inch one way or the other
Old Apr 20, 2008 | 05:29 PM
Montana2x2's Avatar
Yup, I've moved that sucker back and forth across the alternator so many times I expect to wear thru the case any time now. It was pretty fussy to get set up when I 1st installed it but it was working great.
440FURY
Jul 19, 2004 10:55 AM
jiMMyCTD
Jun 26, 2004 06:27 PM
Evildiesel
Aug 7, 2003 08:44 PM
country
Jan 28, 2003 08:15 PM
1stGenBikeHauler
Nov 1, 2002 10:27 AM
