Anyone running an electric water pump?
Old May 31, 2009 | 11:17 PM
CaptainChrysler's Avatar
Originally Posted by Riflemanusmc
If you turn any high RPM, and high RPM on a 6BT is 2200 and over, Yes Sir. you are. The factory pump cavitates, causing blown freeze plugs. Electrical pumps are not the answer. The number 5&6 run hot. Its because of the pump and those two being at the back of the block. Cummins made the factory bypass for a reason. They know it will blow the rear plug and run hot. The electric pump belongs off road... Hope this helps..
I am pretty sure that water outlet was only used when they had air compressors.
Old May 31, 2009 | 11:19 PM
Riflemanusmc's Avatar
Registered user
Originally Posted by mhuppertz
I don't think freeze plugs will blow unless they are rusting out. I just don't know how to get my head to seal up front. I don't want cavitation either.
How about putting an air conditioner clutch on the water pump that slips at higher RPM's...
Yes IT will blow, regaurdless of rust or not..Too much thinking bro.. head stud it if its leaking in the front. The plug that blows out is the one in the back of the block.
Old May 31, 2009 | 11:23 PM
mhuppertz's Avatar
Will studs fix the problem? That front corner of the head is kinda far away from a bolt/stud. I was thinking the head warps under pressure and that's when it starts leaking.
Yea, I know I'm probably overthinking it, but that's cheaper!
mhuppertz
Nov 4, 2011 10:48 AM
pullin hard
Aug 5, 2009 09:35 PM
Dodge Demon
Dec 16, 2008 09:09 PM
Stainless
Oct 16, 2008 11:22 AM
big jimmy
24
May 18, 2006 08:39 PM
