Anyone bought this Battery?
Old 01-18-2019, 06:06 PM
edwinsmith's Avatar
Received 1,037 Likes on 762 Posts
Originally Posted by Bob L
NAPA P/N Bat 7235. Same NAPA Battery as the 7234 with the exception it has a “TOP POST” where the 7234 has a “THREADED POST”
https://www.napaonline.com/en/p/NBP7235
Thanks Brian for the NAPA P/N.....
Battery - Automotive Commercial 12 Volts Group 31P 1125 CCA Top Post
[img]https://media.napaonline.com/is/image/GenuinePartsCompany/1023280?$gif$ Part #: BAT 7235 Product Line: NAPA Batteries
This looks like the one I need! Thanks everyone!
Edwin
Bob L (01-18-2019)
Old 01-19-2019, 01:49 AM
ofcmarc's Avatar
Ever try a CAT battery?
https://parts.cat.com/en/ncmachinery...utput/115-2422
1000cca grp31
I had one in my first 1st gen. Lasted forever and worked great in the cold.
Old 01-19-2019, 02:13 AM
edwinsmith's Avatar
1000cca grp31
The Napa store is a lot closer and the battery has better specs than the CAT battery. The closest CAT store to me is 22 miles away.
Thanks for the input.
Edwin
Old 01-19-2019, 10:34 AM
Bob L's Avatar
1000cca grp31
l’ve had two, they are GREAT, REALLY GREAT !. Built to last, and like you say, work great in the cold.
They just seem to keep going, and going, and going.
A little expensive, but you get what you pay for, sometimes, not always.
in my experience, this is one tough battery. Not sure who makes it for CAT, nor to what plate spec’s, but it’s a HARDY BATTERY.
Cost is the only factor.
Thanks for mentioning it.
edwinsmith (01-19-2019)
Old 01-19-2019, 11:50 AM
u2slow's Avatar
This Canadian Napa battery looks a lot like the CAT.
https://www.napacanada.com/en/p/NAB31100
Can't find the 7234 battery on the canadian site...
Old 01-19-2019, 02:20 PM
maybe368's Avatar
Well, the 2 Odyssey batteries came yesterday and I just installed them. The battery seems to crank over just as fast as the die hard, 1150 cca one that it is replacing. I discovered that the battery isolator was bad, it was easy, I installed the truck one first and when I went to do the 2nd one, I accidentally grounded the positive cable from the isolator and it sparked. It may explain why both batteries tended to go at the same time...Mark
Old 01-19-2019, 07:14 PM
edwinsmith's Avatar
I went down to Napa today and got the battery. Compared to the O'Really one it's a monster! It's taller and longer and 21 pounds heavier.
Here it is installed in the truck.
Hopefully I won't have to charge it all the time and the starter will stop clicking.
Edwin
The following 2 users liked this post by edwinsmith:
Bob L (01-20-2019), nonrev (01-19-2019)
Old 01-20-2019, 02:19 PM
bigredbrick's Avatar
That's the battery I use, 7237. Just replaced it last weekend with another. Lasted 7 years and might have lasted a little longer if the truck got driven more.
edwinsmith (01-20-2019)
Old 01-20-2019, 06:14 PM
Bob L's Avatar
Hi Edwin,
That’s a VERY nice battery. Should last you a long time. Good on you !.
Battery - Automotive Commercial 12 Volts Group 31P 950 CCA Top Post
Part #: BAT 7237 Product Line: NAPA Batteries Warranty: Download
Old 01-22-2019, 02:53 PM
Danderson's Avatar
Originally Posted by maybe368
I bought a Sears Diehard AGP which was made by Odyssey, it lasted 1 month past the warranty, no pro rate at all. I read through the comments on Amazon and this 1 seems to have some longevity...Mark
Same here except it was one battery. Had to buy two so I went with lead acid Duralast's from O'Reilly. Mine were Platinums.
I replaced my original Mopar's(mistake) which are still alive in a 12v.
Dlowkes7
01-27-2011 10:30 PM
jesussaves
11-07-2010 06:55 AM
EdmontonCanada
10-10-2008 11:37 AM
taildragger
38
12-19-2006 09:49 AM
planejane
08-23-2004 03:17 PM
Quick Reply: Anyone bought this Battery?
