Anybody got any experience with aftermarket cruise control? Need one...
As the title states, I need cruise control, especially with the long trips coming in my near future here...anybody know of a good one and where to get it? Who's used what and what does/doesn't work? Thanks,
Brian
Brian
My truck had an aftermarket electric system on it when I bought it. It sucked. The thing would get confused by the turbo lag, so it would give a lot of throttle, the turbo would spool up, and then the truck would take off so it would release the throttle. After about a half mile you felt kinda queasy.
One of the first things I did was rip it out.
A simple real low-tech approach to the problem , you could add a vernier adjust throttle cable to the pump, After you got to the speed, you simply pull the **** and lock the position.
It is the cable you usually use for PTO speed control. The down side is there is no brake release.
Stomp
Did your truck not come equipped with one to begin with? or are you replacing it? or wanting to install one since one has not been installed originally?
If you're replacing one, then go to the dealer and order the part(s). Best system in my opinion.
I wouldn't think twice about putting an aftermarket unit on these trucks.
Brian
ratat98
Jan 1, 2010 11:21 AM
Great_big_juan
Aug 28, 2007 11:14 PM
427AC
Dec 25, 2005 05:04 PM
