Another Ramcharger Cummins Build... but with a twist.
#31
I was able to get the 2wd front assembly off after removing the remaining rivets and the 4 top bolts. I did have to cut the 2 support brackets allowing the assembly to drop down off the frame. I then moved everything forward allowing the front crossmember to clear the frame. I tried to surgically remove the brackets just in case someone wanted to weld everything back together again.
I started mocking up the new 4x4 front end parts. I will set the motor crossmember tomorrow and share more pics of everything coming together.
thrashingcows (09-11-2016)
#33
Lookin good
#34
Okay guys. I used the 88 RC 4x4 to cut out a template. Using a 15/16 socket in the frame guide hole, i located the 4 motor crossmember rivets on a 1/4 piece of plywood.
Here is the template that I will transfer the d250 frame. It should work out prefectly as a carbon copy of the RC 4x4 frame. More of an update tomorrow. :-)
The following 2 users liked this post by lv2bunderwater:
mknittle (09-12-2016),
#36
More demo work and then the build up begins. I also ordered the new GM 56" rear springs. I hope to get the front suspension done this weekend and the rear at least mocked up.
mknittle (09-20-2016)
#39
When I put my 318 on the scale, it weighs in at 642.5 lbs with all the accessories on it. The 4bt is running around 713lbs with no accessories. With A/C, alternator and all the good stuff it comes in around 751.8 lbs. It's a 100lb difference really. 6bt weighs around 1200 lbs? So you're adding around double the weight.
With the leaf springs you cover a huge surface area so the RC frame would handle the 12V easily. The surface area funnels to a point, the axle. I don't think the stock RC axles can handle the 6BT. You might be able to run it for awhile.. but overtime it's not a reliable solution. A dana 60 would increase the point by a much larger tube. King pins are stout and can handle the down/side2side pressure. The ball joints from the dana 44 would take a huge beating.
The other point of failure is the side 2 side motion when you hit a pot hole or a frost heave in the road. I would tend to the cross member, beef it up
#40
While doing some brain storming for my RC build, I re-read this thread.
Whatever happened to the project?
I see the OP was on DTR just last week... Any progress?
I am interested in how you liked those 56 GM springs on a RC.
