Another Hard Shifting RAG
Old Feb 24, 2007 | 12:46 AM
MikeThomas's Avatar
I have a hard time getting into 1 & 2 when at a stop. If I let it roll a little, it pops right in! Any suggestions?
Old Feb 24, 2007 | 06:40 AM
Check the bushing on the master cylinder pushrod. It sounds like the clutch is dragging a little.
Old Feb 24, 2007 | 10:18 AM
MikeThomas's Avatar
The MC pushrod bushing? I would never expect that. Seems like it would at the slave or internal? I will check it out.
Old Feb 24, 2007 | 10:37 AM
tboling's Avatar
Exclamation
The best way to fix the bushing is, to do away withe I hole on the clucth rod and buy hime joint, Just like the powerstroke guys use. I have replaced that crapy stock bushing too many times.
Old Feb 24, 2007 | 11:32 AM
Yep. Just cut the eye off and thread the shaft for 3/8-16. That's how mine is. Lets you set your own clutch pedal height, too.
Old Feb 24, 2007 | 11:46 AM
MikeThomas's Avatar
Ok, interesting. I looked under there and I would say there is only 1-2mm of play. How does that affect the disengagement of my clutch. It seems so miniscule compared the total throw of the setup?
Old Feb 24, 2007 | 12:14 PM
torquefan's Avatar
Good advice above. I would also suspect a worn pilot bushing. If it's too sloppy to keep the input shaft true, the clutch may not completely disengage. It may also make a groaning or rattly noise during clutch engagement when the truck is initially starting to move.
Old Feb 24, 2007 | 12:22 PM
Sounds like it's not the problem, then. How far up from the floor does the clutch engage?
Old Feb 24, 2007 | 02:51 PM
MikeThomas's Avatar
I would say out of the entire throw, it engages in the last 30-25 percent...So at the top.
Old Feb 24, 2007 | 03:28 PM
That's good, it sounds like it's traveling far enough to disengage the clutch all the way.
What lube are you running in the trans?
Old Feb 24, 2007 | 05:40 PM
MikeThomas's Avatar
Er, um, Canola? Actualy, I really nead to to drain it...all ive done is add a quart to it-without knowing how much is in it...I know, I know dad, I should do that.
Old Feb 25, 2007 | 12:08 AM
Get yourself some Royal Purple Synchromax oil.
Old Feb 25, 2007 | 12:16 AM
Bill Tomlinson's Avatar
This may be way out in left field but last year my truck did about the same thing.
It turned out that one of the two bolts that hold the slave cylinder in had fallen out.
The plastic housing would then bend when the clutch was activated.
I could not spot this until I had someone else press the pedal while I watched what was going on.
Old Feb 25, 2007 | 12:17 AM
That's a good suggestion, Bill.
Fergavs
Dec 20, 2006 02:07 PM
pred
Jul 6, 2006 08:23 AM
tfarm
Jan 12, 2006 09:01 PM
Jim Lane
Aug 28, 2005 06:52 AM
carl20320
Sep 30, 2003 05:20 PM
