Another A/C Issue
Old Jul 19, 2016 | 10:10 AM
rrgrassi's Avatar
Another A/C Issue
Well, on Sunday afternoon, the A/C quit again. No power to the compressor clutch. I found that there is a 3 wire connection that runs to a metal box mounted by the expansion valve. When I jiggled the that connector, the clutch engaged, then stopped. Then I disconnected and reconnected the wiring, clutch engaged, then the box released it's magic smoke...making the compressor clutch disengage, again.
What is the box for? Where can I get a new one, or can it be bypassed?
I just checked again, the suction line temp probe is attached to it as well.
Got it out of the truck-here is a picture.
Thanks!!
Attached Thumbnails Another A/C Issue-ac-temp-probe.jpg
Old Jul 19, 2016 | 07:01 PM
Jim Lane's Avatar
You let the magic smoke out of the cycling switch.
This controls the evaporator icing by cycling the compressor, it can be bypassed and you can control the compressor using a mechanical thermostat.
I have seen the switch for other chrysler applications that should adapt.
Old Jul 20, 2016 | 08:50 AM
rrgrassi's Avatar
Jim, do you have a part numbers for the applications? I found an EVERCO that goes by the evaporator, but do not know how to wire it in.
I disassembled the unit, and the relay is what let go, and it burned the board at the relay.
Thanks!
dan123dbl
Feb 13, 2015 05:47 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
Timberman
13
Apr 6, 2006 05:45 PM
DDysput
May 5, 2004 07:44 AM
