Amp mounting
Old Jan 12, 2010 | 06:50 PM
bariley's Avatar
Amp mounting
i dont even know if any of yahs have amps, but im tryin to find a good place to mount it. its a good size. thanks in advance for your oppinions.
Old Jan 12, 2010 | 06:55 PM
comptz's Avatar
mounted mine on a box behind the seat that held my 2 10 inch subs and my 2 6x9 speakers, then i went to individual sub boxes but kept the 2 6x9's in one box, then mounted the amp on the back wall behind the seat
Old Jan 12, 2010 | 07:15 PM
schamran's Avatar
I have mine under my driver's side seat. I left the controls of it to the drivers side so I could adjust it. I have a shelf behind the seat for storing guns/ammo, a flashlight, and a window scraper. Under the seat or the roof were my options.
Old Jan 12, 2010 | 08:43 PM
CONFEDERATESON's Avatar
i had a big box with a 12 behind my seat so i just put the amp under the drivers side and it was good under there. it makes it easier to rout the wires too insted of going down the side of the cab and back around the seat imo.
Old Jan 16, 2010 | 11:40 PM
Rott-n-dawg's Avatar
I have not got around to it yet but I have been looking at putting my two amps behind the jump seats one on each side. I'm hoping there might be some room behind the interior panel. I just have not had the time to pull the interior apart to see. Just make sure the amps will still get good ventalation around them so they can disapate the heat.
Old Jan 16, 2010 | 11:45 PM
ofcmarc's Avatar
There is a good flat spot on the tranny hump near the back edge of the seat. Just in front of the seat belt mounts. That's where mine is. Don't know how big you're talking about though.
Old Jan 16, 2010 | 11:49 PM
GasganoFJ60's Avatar
I have a small amp. Its a Fosgate 250.2. Mine is under the drivers seat with a big box holding two Orion Comp 6" subs behind the seat.
Old Jan 17, 2010 | 01:48 AM
ofcmarc's Avatar
Not much room there if you still want the seats to flip up. And nothing really to mount to. That said with a bit of work I stuffed my 8"s in the seat wells and just leave the seats fliped down.
Old Jan 17, 2010 | 09:30 AM
dillenger1's Avatar
Ok now what about 10"subs in a regualar cab?boxes for under the seats?
Old Jan 17, 2010 | 12:25 PM
Dean Snow's Avatar
I pulled my seat out of my truck and mounted it under the drivers seat. Probably could do it with the seat in but it was a lot easier with it out
Old Jan 17, 2010 | 04:28 PM
JustRamIt91's Avatar
dont get alpine subs... they are too deep, unless you want to raise your seat an inch or too.
Old Jan 18, 2010 | 02:10 PM
92smokin blacky's Avatar
got my amp under the seat and a 15" sub in a huge box behind the seat.
Old Jan 18, 2010 | 02:54 PM
B-North's Avatar
I have a 12 in a huge box behind my seat (can't use the jump seat now) and i just screwed the amp to the box on the drivers side so it's out of sight and then slid everything tight into the corner and bolted it all down. edit thieves
Old Jan 19, 2010 | 04:55 PM
bariley's Avatar
haha i have the same problem now!, jump seats are now only used for emergency drives to the party and emergency drives home! i was kindof thinking of mounting the amp to the bottom of the jump seat, wonder if that would work.
waveone
Aug 17, 2014 01:16 PM
Ridiculous
May 17, 2007 07:28 PM
Mark Hodowanec
Feb 26, 2006 08:35 PM
surfram
Feb 12, 2004 07:20 AM
atc250r
Mar 22, 2003 12:27 PM
