Alignment and still pulling
How are the rear tires? I don't know too much about 2wd's so this is all I can ask...Mark Also check the spring u-bolts to see if the rear axle has shifted, this is a shot in the dark, which is also my favorite Peter Sellers movie...
Did they give you a printout from the alignment? If you posted it here, somebody may be able to see something that was missed. If there's a thrust angle on the rear axle, it can cause a pull. I would also try swapping the front tires left to right. I know they're new, but I have seen new tires pull, more than once. Never with Michelins though, incidentally.
Generally, if it's a pull to the left, it's usually a more obvious problem than a pull to the right. If it's a problem with alignment angles, for example, it has to be out quite a bit more to overcome road crown and pull the vehicle left.
Farmer Duke
Nov 10, 2011 06:25 PM
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
caffecapri
26
Jan 21, 2007 08:02 AM
