Air ride pictures for Stick4trucks.
It could still bend. Remember your only working with 3" to 5" max tube size in the spring area. Your stock spring bushings are 1.25" dia X 2 13/16" wide. So there is one limitation to deal with. Then you have to deal with a spring mount that is not much larger than the OD of the spring end. This is the biggest issue. It doesn't allow much upward travel on an air ride. This would cause bottom out of the arm. Plus that rubber bushing will cause problems. It does not have enough give or twisting travel. BTDT and still fighting it.
On square box I would put weld slugs into the tube to control the chance of bending/ twisting.
Look at Curriey johnny joints.
Currie Enterprises
I am not a fan of poly bushings. I hate heim joints even worse.
Currie Enterprises
Currie Enterprises
Currie Enterprises
Rushford
23
Aug 26, 2007 07:21 PM
