Air Conditioning Still doesn't work?
Old Sep 7, 2007 | 06:53 PM
  #31
dodgge1ton's Avatar
the deep vacuum on the small system is not as important as it holding it. 20 in. is just fine. hold it for a few hours you are good to go! Any leak or water in the system will make the vacuum go away. You will get it
Old Sep 8, 2007 | 07:57 AM
  #32
leper's Avatar
What do you mean by saying you put a sealer in it?
Take your truck to a buddy that has an AC machine and let him charge your system by weight. That is the only way to know exactly how much refrigerant you are using.
Old Sep 10, 2007 | 08:27 PM
  #33
dodgge1ton's Avatar
You said here you put sealer in it. It seems to react with air and at the valve it will sometimes gum up around valve and not let it seal correctly.
Originally Posted by MJDiesel
In response to loch's post, I have gotten a reading when the thing was not running. I will have to do it again to refresh my memory, but I know that the low side reading was very high (like 2-300, past where the guage registers), and I think that the low side was 150 or less.
I changed to 134, because the thing did not work and 134 is cheap! The compressor did not engage, so my guess is that it had a slow leak (didn't work too well last summer), and I should add that I have put a sealer in it. I tried that Freeze 12 stuff, but it did not work, which seemed kind of odd. A bigger problem maybe???
I did get some oil out of the system here and there, but probably not too much. I tried to remove the compressor to drain it, but after breaking a few wrenches and gettting angry, I decided that thing aint coming off unless it needs to! Is there any good way to get oil out of the system without draining the compressor? I added, well, too much of the ester oil.
One question: If I do not replace the dryer right away, will the system still work so I can do some troubleshooting for other problems? For the time being, I am not looking for a clean, prefect system recharge.
Old Sep 10, 2007 | 08:52 PM
  #34
MJDiesel's Avatar
Thanks for the heads up. I will remove the valves and check them out before I recharge. Today, I finally got time to work on the AC. I pretty much took everything apart and cleaned it with alcohol. I got everything back together, while installing the new dryer and EV. So, I just need to evac the system a little longer, then charge it and see if all of my work was worth it!
code7
Aug 6, 2006 11:41 PM
Dave65
Sep 7, 2003 11:16 PM
ET RAM
Aug 26, 2003 07:16 PM
sherod
Jul 5, 2003 11:13 AM
