Adapting my np205 to a 47RE?
Hmmm, is there any kits out there to adapt my NP205 to a 2002 47RE? Just thinking about some stuff and want to educate myself a bit.....
If you are putting it in the 93 listed in your sig, you must know that the 47RE is shifted entirely by the computer, and the 93 does not have the circuits in the PCM to do that. Each gear is shifted by an electronic signal from the PCM. If you get a 47RH from a 94-97 diesel or V-10 truck, only the overdrive and lockup is controlled electronically, and 1st, 2nd, and 3rd is shifted automatically from hydraulic pressure. I have a wiring schematic drawn up in my gallery that shows how you can control O/D and L/U semi automatically with a double momentary toggle switch(or switch of your choice) and six relays. It disengages when you tap or step on the brake pedal. Very cheap, simple, and foolproof. Or you can use pressure switches to control them. The problem I hear everyone complain about when the tranny is controlled by computer or pressure switchs, it engages either too soon or too late, and disengages either too soon or late because when your driving conditions change, it doesn't. My way never engages or disengages unless I tell it to.
Good to know, sounds like more trouble than its worth.
Well, not really, the 47RH is just slightly more trouble than installing the 518. I did it. I wish I had researched before I started gathering my parts and found out what I just told you though. I gathered up everything from a 93 auto to go in a 93, and later went out and bought everything again from a 95 auto truck to get the lockup TC I needed. You will be much happier with the 47RH over the 518. You will also need a different engine adapter and a different starter if you get a 47RH.
Yeah, but I dont want to have to rig up things to drive the RE electronic controls...
You can buy a 29 spline output for the re. The rh only comes with a 23. I had to make a 23 to 29 spline coupler for mine. I was told the 23spline input for the 205 would not hold up.
Give "advance adaptors" a call they can hook you up with what it takes to get it mechanically sound.
Originally Posted by MikeThomas
(Post 1988011)
Originally Posted by RonA
(Post 1988075)
Originally Posted by bloodhound51
(Post 1988636)
