AC issues
AC issues
My compressor was working but there was no apparent movement of refrigerant so I replaced the expansion valve.
The system held a vacuum just fine but when I went to recharge the system equalized with the can at 110 psi on both sides. The compressor wouldn't kick in. When I jumped the relay the compressor spun up and it started pushing oil out of the line fitting at the expansion valve and I did not see an increase in pressure anywhere.
When I stopped the compressor the leak stopped but both sides held 110 psi.
I'm kinda stuck on this one. Any ideas?
Anytime you open the system you should replace the filter/dryer. I may be plugged up and stopping the circulation. Rock Auto has them for cheap. I recommend the Four Seasons brand.
I finally accumulated all of the supplies and parts to convert my A/C back to R12. The R12 was the most expansive part. I got a new Filter/Dryer, Expansion valve and some system flush. I also got the POE oil that is compatible with both R12 and R134. I'm just waiting on cooler days so I can do the job.
Keep us posted on your progress. Hopefully others will chime in with ideas.
Edwin
Edwin
67HotRod
May 12, 2016 04:38 PM
KATOOM
Aug 13, 2015 12:52 PM
SimpleSailor
Apr 26, 2015 06:59 PM
junkyarddog_88
Mar 19, 2009 12:14 PM
