A518 Wire
Old Feb 11, 2013 | 07:14 PM
1972RedNeck's Avatar
A518 Wire
There's also a Wire on the driver side of the A518, If you GROUND that wire. That will engage o/d. With the key on it should be the wire that DOESN'T have 12 volts to it.
Someone on here will know exactly which wire I'm talking about. I'm 1% sure It's blue. But 99% sure I'm wrong
Where is this wire located? Is it blue? Where is the best place to tap into it?
Old Feb 11, 2013 | 08:18 PM
j_martin's Avatar
12 Power is Blue.
Ground from PCM is orange/green tracer. With the switch on it'll likely have 12v on it also (through the solenoid) You can force it to ground without hurting the PCM.
Old Feb 12, 2013 | 06:44 AM
So I need to ground the orange/green wire? Where is the best place to tap in (easiest place to find it)?
duallydave
Jan 22, 2009 04:50 PM
Rollin Smoke
Oct 24, 2006 10:24 PM
Txwelder
Feb 11, 2006 10:32 AM
matthopp
May 11, 2004 04:38 PM
TPilaske
16
Nov 22, 2002 08:15 PM
