A518 Slushbox Goo
Received 1,637 Likes
Truck was dropped off at the rebuild shop. With any luck, I'll be served with dignity, and they will do a great job on the rebuild.
Time will tell.
Thank you all for your insight and advice
Time will tell.
There is a list of the codes in the sticky somewhere. I doubt that the codes are going to help if the blue wire has 12 volts and grounding the orange wire doesn't get you O/D because that bypasses everything except the solenoid. If it's not the solenoid then it's mechanical in the transmission.
By golly you are right! I just checked and there is a plug there, it was tucked up under the vacuum sensor. Never noticed it and nothing in the manual ever referred me to it, just the key on/off/on procedure...
So, you upgrading the tranny while it is out? You plow with this truck right?
The following 2 users liked this post by NJTman:
edwinsmith (11-10-2018),
nonrev (11-10-2018)
BUCKEYE4X4
08-28-2007 08:32 PM
gsdog1
08-03-2004 12:25 PM
John Rodriguez
02-23-2003 07:48 AM
