95 piston lp? low pressure?
Old Dec 3, 2008 | 05:57 PM
STACKED's Avatar
im kinda low on cash right now and i was going to yank the afc lever out of the truck but i dont want to run the pump dry. i have a 95 12v parts truck and my question is that is the piston lp on that truck a low pressure unit. also is everything on that truck what i need to do th conversion, like the spacer the line and so on.
Old Dec 3, 2008 | 06:16 PM
bgilbert's Avatar
Mostly no. The spacer will work and the pump will work with a regulator, but that's it.
Old Dec 3, 2008 | 06:20 PM
archer39's Avatar
what he said^^^ if you don't run a regulator you will blow the front seal out of the VE pretty quick.
Old Dec 3, 2008 | 06:42 PM
STACKED's Avatar
the line from the pump wouldn't work. would a holley blue regulator work i dont know about spending over 100 bucks on a regulator?
Old Dec 3, 2008 | 06:44 PM
archer39's Avatar
you can get a Simflow bypass regulator for about 30 bucks i believe. do a search for it, i can't find the link right to one now.
Old Dec 4, 2008 | 12:45 PM
STACKED's Avatar
i checked vulcans web site but i dont see that regulator anywhere.
Old Dec 4, 2008 | 01:25 PM
The_Head's Avatar
I thought the piston LP came in low and high pressure flavors, and the low pressure LP could be used without a regulator.
Old Dec 4, 2008 | 03:00 PM
STACKED's Avatar
thats what i thought but i cant seem to find out which ones are low pressure
Old Dec 4, 2008 | 03:08 PM
unixcowboy's Avatar
PN 396320 low pressure LP 15 -16 psi
or
Case PN J96320
Old Dec 4, 2008 | 03:16 PM
The_Head's Avatar
I read somewhere or somebody told me the low pressure variant is good for about 350 whp.
Old Dec 4, 2008 | 03:23 PM
bgilbert's Avatar
I did 450rwhp with 3936320 and stock fuel lines.
Old Dec 4, 2008 | 03:26 PM
The_Head's Avatar
most excellent.
Old Dec 4, 2008 | 03:27 PM
unixcowboy's Avatar
Was that before the 14mm head ?
Old Dec 4, 2008 | 03:34 PM
STACKED's Avatar
did that pump ever come stock on a truck?
Old Dec 4, 2008 | 03:59 PM
apwatson50's Avatar
A 3/4 or 1 ton truck produced by dodge? NO
A medium duty truck or motor home? Probably.
