93 electrical problems
Old Feb 14, 2013 | 02:13 PM
doug holt's Avatar
Hello guys yesterday i got in my truck to come home turned on my lights i had no park lights or no dash lights well i took a jumper and jumped over a fuse and made it home the day before my windows and blower motor would stop working and go back to working you can tak a test light and put on fuse neither side is hot where does that hot come from and does it run thru pcm any info would be great
Old Feb 14, 2013 | 02:29 PM
crazzywolfie's Avatar
the windows and blower motor might be a separate issue from the rest. sounds like the fusible link might be going bad. should be the orange fusible link connected to a pink wire. are all the fuses good?
Old Feb 14, 2013 | 03:49 PM
doug holt's Avatar
Yes all fuses are good the pink wire under dash was the one starting to melt thank you for info it is greatly appreciated
Old Feb 14, 2013 | 04:14 PM
93-12Smoke's Avatar
Could be the ignition assembly too
Old Feb 14, 2013 | 05:58 PM
sounds like it may be time for you to do the blower motor relay upgrade. if that pink wire is starting to melt then that is most likely why your blower motor and windows quit working. if you put the blower motor on relays it should remove stress off the pink wire but you should probably replace the pink wire. i think it should run from the ignition switch to the fuse panel.
https://www.dieseltruckresource.com/...d.php?t=158400
Old Feb 14, 2013 | 06:57 PM
j_martin's Avatar
I can see switch contacts deteriorating with age and heating up till failure, but a wire, including a fusible link shouldn't.
Odds are good your heater motor is nearing end of life and drawing excessive current.
Old Feb 14, 2013 | 07:46 PM
doug holt's Avatar
Thanks guys I will dig deeper tomorrow the blower motor was put on this past summer new the light switch bracket was kinda loose tightened it up a little the lights seem to have a better ground will get back on it tomorrow thanks again
Old Feb 17, 2013 | 12:50 PM
Chrisreyn's Avatar
I just recently had this issue... windows/blower worked fine, then suddenly quit altogether. Funny thing is, when I would depress the window switch, my wait to start light, brake and water in fuel would come on..
The problem wound up being the fusible links, pink( faded red actually) with black trace if I recall correctly, and one of the two smaller brown wires..
here's a link to my thread on it..
https://www.dieseltruckresource.com/...e-t309187.html
DJ Turbo.
Oct 13, 2011 09:11 PM
David Kee
Oct 11, 2003 08:33 AM
FastSS
Sep 8, 2003 01:47 AM
FastSS
Jan 8, 2003 05:53 PM
TurboAZ
Oct 11, 2002 12:34 AM
