90 Brake problem solved
Hello all, I am posting this for the information to be passed on and maybe somebody else will benefit. I have a 90 w250 with a getrag and 4 wheel drive. It has had many of the brake maladies that I have read about on this forum. The worst being no brakes at all and very hard and stiff, inefficient braking.
To make a long story short, I went through the whole system once, including a rebuilt rwal modulator valve. At that time I did not replace the proportioning valve on the advice of no fewer than 3 "experts", most saying " I have x number of years working on these and I have never replaced 1".
Well, after having the same problem I decided to replace the proportioning valve and if that didn't work, I was going to chuck the whole antilock system and put disc brakes in the back ( which I will probably do anyway). Fortunately it worked, the brakes work as new. I found a new mopar valve
here http://wermopar.com/?gclid=CNH5zITpuJwCFR0SagodLicloA
Please forgive me if this is common knowledge, but their prices are considerably lower that any place I could find. Thanks for all the info on this forum, I could not have figured it out without it...Mark
No, they didn't pull, the brakes light and the Antilock lights would come on and I would have no brakes at all. That led me to replace the dump valve, but that didn't solve the problem. I believe that the proportioning valve was stuck and most of my braking was coming from the rear. I read somewhere on this forum a thread that talked about recentering the valve, but I couldn't find it again.
The valve was 135 dollars, less than the dump valve was. I am not sure how this affected the rwal system, but it did...Mark
Lary Ellis (Top)
55
Nov 8, 2012 10:22 PM
RBRam
Apr 12, 2005 04:26 PM
