89 SRW 1 ton got weighed today
Old Mar 29, 2007 | 02:16 PM
pred's Avatar
Have to run to the scrap yard today, and the truck got weighed going in and out,,,
5,720 lbs,
Only things to add weight, 1/2 tank of fuel, Alum tool box and about 200 lbs tools, and me, 165 lbs,
So that brings us to 5,355 LBS of cummins toting dodge.
Just in case you were wondering how much a SRW 1 ton 5 sp weighs.
Peter.
Old Mar 29, 2007 | 03:01 PM
BigDiesel396's Avatar
that seem awful low...my 95 chev ext cab long box 4x4 auto with the 6.5 turbo diesel in it weighed in at 6480 with 3/4 tank of fuel and me in it (160lbs). I believe the cummins weighs approx 600lbs more than the 6.5 so i dont know where you'd be saving all that weight...
Old Mar 29, 2007 | 04:19 PM
zinkie's Avatar
At the truck pull mine weighed 5750 with about a 1/2 tank and me, lets just say it didnt do so well at that weight in a 8000 lb class
Old Mar 29, 2007 | 04:37 PM
pred's Avatar
Being 2 wd saves some weight right off the bat, I believe it to be correct, I hav my landrover discovery on a scale, and i knew what it weighed, and the scale was right! I have The basic 2wd truck, no power mirrors ect, just a good work truck, The bucket seats i added weigh a bit more than the bench did, so in reality i guess that it actually should be a bit less.
Peter.
Old Mar 29, 2007 | 05:21 PM
TractorMike's Avatar
I got my truck weighed the other day at the landfill.Going across the scale I was 7000+, When I came back empty I was 5,760 which I thought was kinda heavy, That was with me out and the truck had 3/4 tank of fuel. This is with the truck in my sig. later, Mike
Old Mar 29, 2007 | 06:26 PM
DeanM's Avatar
Hmm, I weighed mine the other day. Empty with me and my dog it weighed 7500lbs.
Dean
Old Mar 29, 2007 | 06:56 PM
woodrat's Avatar
seems like mine was around 8000 last time I went to the dump..
Old Mar 29, 2007 | 07:58 PM
BTM's Avatar
BTM
Mine always came in around 7400 lbs. Tool box on the bed and me (180) Rich
Old Mar 29, 2007 | 08:27 PM
wheelo90's Avatar
Weighed mine the other day and I went across the scales at 7,750 lbs.
I had 3/4 tank of go juice, and 150 lbs of me.
5,700 lbs sounds somewhat low, but I know 4 Wheel drives are heavy.
Old Mar 29, 2007 | 08:35 PM
JKM's Avatar
JKM
FWIW, on a certified scale (portables like the DOT has , I have a set) my truck (95) weighed in at 6300lbs, Apoc's 93 250 4x4 CTD (with plow gear still installed) weighed in at 6280 lbs.
Old Mar 29, 2007 | 08:36 PM
materdiesel's Avatar
Believe you me, an axle, t-case, bigger tires and an extra driveline don't weigh an additional TON!!!
Old Mar 29, 2007 | 08:58 PM
dpuckett's Avatar
They'll add 12-1500lbs.
I had a 91 nonIC, reg cab pickup dually, 2wd with a 5spd. Weighed right at 5000, I think. The 92 in my signature weighs 7180 with me and my tools out of it, about 3/4 tank of fuel. Mom's 92 (identical to mine, except reg bed and auto) weighs 5500.
DP
Old Mar 29, 2007 | 09:09 PM
alborada's Avatar
just weighed yesterday 7120 lbs going in the dump 6800 coming out. my 90 d250 was 5400 I think, Yes 4x4 and an ex-cab are much heavier. Not a ton no but close!
Old Mar 29, 2007 | 11:01 PM
GLHS's Avatar
Non intercooled trucks have a 6" frame; intercooled trucks are 8".
I can get my truck down to 6100 with half a tank of fuel and removing the sway bar, spare tire, skid plate, jack, tailgate and hitches. Normally my truck wieghs around 6700.
Old Mar 29, 2007 | 11:22 PM
woodrat's Avatar
If I cleaned out all the tools and stuff behind and under the seat, I might be able to get it down under 8000...
