89 fuel heater
Does anyone make a threaded piece to get rid of the fuel heater on a non intercooled engine? I live in southern AZ so i don't need a heater and i am really tired of mine seeping and loosing prime( if it sits for a week i need to work the lift pump lever) and the side of the filter is damp.at any rate it need's to go. I was going to cut the center out of mine and reweld it but if i can find one done!! Any Help??:(
Here you go :
https://www.dieseltruckresource.com/...d.php?t=192367 and here : https://www.dieseltruckresource.com/...80&postcount=7 I had the same situation you are having. My leak started when the whole mess un-screwed with the fuel-filter, on the side of a busy road; after that episode, it leaked intermittently, sometimes a seep, and sometimes a flood, constantly running down the sides of the filter. I removed the heater and swapped the stud = no more leak. The extra inch of clearance was also a plus, as I use the much longer FS1221 filters. |
fuel heater
Thank You BearKiller!!!!!!!!!
