6 spd Conversion
Old Jan 8, 2008 | 05:06 PM
torque6's Avatar
Question 6 spd Conversion
I was wondering how hard and what it will take to put a 2001 nv5600 4x4 in to my 1990 D250 4x4.
thanks
Old Jan 8, 2008 | 05:41 PM
woodrat's Avatar
ka ching!
I thought about it too, when my getrag died, but the changeover for that was out of my financial reach.
Old Jan 8, 2008 | 06:05 PM
Fred Swanson's Avatar
depends on what all you got, if you already have a trans. Adapting to the cross member is the biggest issue. other obvious stuff, d-shafts need to be adjusted. Maybe explain what you have available, so we can tell you what else you will need. It isn't a cheap conversion, but if you already have a manual, your most of the way there.
Old Jan 8, 2008 | 07:38 PM
RonA's Avatar
I put a 6speed from a 2002 into my 92. Not a problem. Made a cross member and had to modify the 29 spline coupler, drive shaft mods and a new clutch and slave. That's about it. The hole in the floor needs a bit of work, and if it's 4 wheel drive, you'll have to make a new mount for the transfer case linkage. I recently swapped to an auto so i can't take pictures.
Old Jan 9, 2008 | 01:42 PM
torque6's Avatar
I have a 2001 2500 6spd 4x4 that is a complete truck nothing has been takin off of it.
Old Jan 9, 2008 | 01:56 PM
So you have pretty much everything you need to do it then.
Old Jan 9, 2008 | 02:01 PM
torque6's Avatar
yeah just got to talk to my buddy about goin and gettin it. will the clutch and fly wheel work off of the 01 on my 90
Old Jan 9, 2008 | 02:40 PM
DNRCustoms's Avatar
So, Are you liking the 47rh better thsn the 6spd?? I am working on finding a 47rh and doing the conversion on my 92. I doesn't look to be all that hard.
Old Jan 9, 2008 | 02:57 PM
RonA's Avatar
The auto is fairly user friendly. Just a lock up switch and an overdrive button. Very easy to stay up with the flow of traffic in town. Total waste for towing. I loved the 6 speed and the mileage I got. Lost a bit with the auto, but I have been having some knee problems and it was either an air operated clutch or an auto.
Ron
Old Jan 9, 2008 | 04:35 PM
torque6, as was mentioned earlier by others, you have to take the engine to trans adapter from the 24V motor, along with the starter, clutch, flywheel. They will alll work.
Old Jan 9, 2008 | 04:54 PM
mwlu711's Avatar
you may need the fly wheel adapter plate clutch starter and belhousing for the six speed but advanced adapters may have an adapter belhousing for this aplication then all you wil need is the trans and what ever it takes to hook up the t case.other than that if you have some fabrication skills or friends that do and acsess to the equipment and some machinest skills you have it made.one last thing use locktite on anything you dont want coming apart use red on the flywheel bolts an blue on prety much evry thing else.
good luck and enjoy.
Old Jan 10, 2008 | 12:20 AM
torque6's Avatar
thanks for the info i appreciate it.
Old Jan 10, 2008 | 08:53 AM
Trebor's Avatar
I looked at doing the six speed conversion but opted for the NV4500 instead.
My reasons at that time were:
1. Initial cost of the six speed over the NV4500 was close to $1,000.
2. Drive shaft fabrication was going to be over $750 for lengthening & shortening both drive shafts locally.
3. Availability of repair parts for a transmission no longer being manufactured.
4. How I use my truck, primarily as a grocery getter, no real need for an extra gear.
Yes, at times in rare traffic situations I could use the extra gearing but I always manage to get by without any difficulty. In my opinion it just wasn't worth spending almost an additional $2,000 to have it.
Old Jan 10, 2008 | 09:44 AM
RonA, sounds like you need a more optimal TC. The autos can tow fairly nice, but 6 forwards are better than 4.
The bellhousing from the 6speed is integrated into the trans, no swapping available.
He's getting the trans for nothing, it sounds like, so the only concern would be if/when he might need to have it rebuilt, it does cost almost 3x as much as the 4500.
$750 for driveshafts? Yikes, there are less expensive places out there. I picked up a new front for my 93 for under $250, new CV, shaft, new longer clearanced slip yoke included, since my old one was shot, and I had lifted the truck too.
