4x4 front brake rotor?
Is the front rotor part of the hub or is it serviceable separately?
I was expecting to replace the hub and rotor ASSEMBLY but all the parts stores are trying to give me a rotor only.
Is the rotor pressed on separately? I swear last time I needed one, it was the whole assembly.
they are separate, that hub is uber expensive too... and only if your truck is seriously rusty do you need an air hammer, put the assembly on a block of wood and a good old BHH will work just fine.
From: A 5th dimension, beyond that which is known to man.
i like the air hammer because its easy, doesnt smoosh the end of the stud and its what i use to put the assembly back together.
im sure you can use a normal hammer but its just so easy with air tools lol
Got it done today. Easy as pie. Brass drift to get the studs out and an steel one to put them back in with. Now I just have to retorque the lug nuts a couple times a day to make sure they stay tight and the studs are seated.
schamran
Nov 22, 2010 07:08 AM
