47rh and transfer case questions
Old May 15, 2011 | 07:10 PM
big stinky's Avatar
Hey all,
Gonna put a p-pump 12 valve in my blazer with a 47rh as well as a dodge kingpin dana 60.
This leaves me the problem of what transfer case to run. I have a chevy 205, and the case off the 47rh, which is clocked the wrong way.
Anybody have any parts swappin information they would like to share?
Do the dodge 205s bolt up to the 47rh's? What about the splined coupler in between them?
Can you reclock the cases?
Thanks.
Old May 15, 2011 | 07:13 PM
sooty's Avatar
clocked as in front drivers side axle input? output 205 passenger side is axle swap. off road designs, in co. might have other ideas.
Old May 15, 2011 | 07:35 PM
JD730's Avatar
The dodge NP205 will bolt right up. Tail case on an A518 is the same as a 47RH.
Old May 15, 2011 | 07:46 PM
sooty's Avatar
my bad, for some reason, iwas thinking different case
Old May 15, 2011 | 09:07 PM
big stinky's Avatar
JD: Thanks!
Sooty, goin for the passenger side drop.
Anybody know about the chev 205? It came off a th400...
Old May 15, 2011 | 09:22 PM
sooty's Avatar
the th400 has 32 spline input, the input shaft is easily replaceable, you need 29 sp.
Old May 16, 2011 | 04:09 AM
JD730's Avatar
Negative, 29 spline is for dodge manual transmissions. He would need a 23 spline input for a dodge automatic.
Old May 16, 2011 | 08:35 AM
sooty's Avatar
yep, still thinking wrong, thanks for the many corrections to all. i can find correct input patrs like that from standard transmission.com, and local rebuilder resources, ive seen the input gears on ebay too, if you have trouble locating, i can help, with new or used.
Mopar1973
Oct 23, 2012 09:25 PM
wyododge
Aug 18, 2011 07:48 AM
Rick 12v CTD
Jan 10, 2010 11:28 AM
boiler-rat
Oct 10, 2006 10:28 PM
