4000 pound upper control arm
Old Nov 26, 2010 | 03:54 PM
Fordkiller's Avatar
to make a long story short i need a driver side control arm for my 93 1 ton cant afford the dealer right now already spent to much on there could be crap replaced every thing they said over the last year and the retards could not see it was the bushings till the contol arm riped also need a door latch from inside the door driver side power locks and windows no junk yard ive been to or called has eather one need help please down to just the truck and need parts fast any ideas
Old Nov 26, 2010 | 04:29 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Try posting a want ad in our free classifieds section.
92betsy's Avatar
I got mine from a ebay store after a new dealer one got bent up and they wouldnt fix it. It came with the ball joint pressed in and has lasted about 3000 miles longer than what the dealers did so far. Only paid 75 or so shipped to.
Old Nov 26, 2010 | 05:00 PM
ofcmarc's Avatar
For the door latch, pull it out of the door and soak it in a can of diesel for a while and clean the crap out of it. Dry it off really well then re-lube it and re-install.
It'll probably last a bit longer. (I nursed mine along that way for 3-4 months last winter this way) Hopefully long enough for you to find one in a junk yard or a classified somewhere.....
Old Nov 26, 2010 | 06:14 PM
Fordkiller's Avatar
ok ill try that thank yall ill let u know how it turns out
Old Nov 26, 2010 | 06:35 PM
Upper control arms are the same from a D150 to D350, 1980-1993. The only difference is that on the diesels, and 4000 lbs front ends the y used a HD upper ball joint. But other then the size of the shaft on the ball joint being bigger the ball joint will screw into any upper control arm.
Old Nov 26, 2010 | 06:58 PM
Fordkiller's Avatar
so would it be safe to say i coule use anoth one for a temp till i can find a new one i was told i could not
Old Nov 26, 2010 | 07:40 PM
ofcmarc's Avatar
Just remember the door parts from gassers and Ramchargers work for ours as well.......
Old Nov 26, 2010 | 07:48 PM
so would it be safe to say i could use another one for a temp till i can find a new one i was told i could not
Only thing you'll need is a HD 4000lb ball joint if you grab a used one from another truck. Unless of course it already has the big ball joint. The eccentric cam bushings were the same from the late 60's on up to the mid 90's.
When I redid my upper control arms on my D350 I used a NOS set of bushings from a late 60's/early 70's chrysler C-body I had kicking around. Fit perfect and were identical to the originals from the truck.
Old Nov 27, 2010 | 01:01 PM
Fordkiller's Avatar
cool so if i understand right the ball joint is the only diff and the 4000 pound ball joint will fit in place with no problem or do i need to tap and die it first because it is a screw in
Old Nov 27, 2010 | 02:55 PM
Onemoparnut's Avatar
They were all screw in no matter the weight rating. The 4000 pound joint is just bigger where it is tapered and goes into the knuckle.
Old Nov 27, 2010 | 03:23 PM
Fordkiller's Avatar
ok cool thanks a bunch have line on a 3300 pound one ill get monday let you how it turns out
Old Nov 27, 2010 | 09:18 PM
gadget.35-06's Avatar
Just watch to make sure the ball joint doesn't back out of the arm. I wailed on the uppers on my 91 and the left one still unscrewed. You may need to tack it or perhaps use Loctite. Keep an eye on it.
Old Nov 27, 2010 | 09:25 PM
Fordkiller's Avatar
man the responce i gotten has been great had some pm me with the right one for the old so going to get that one from him now some one has taken the tow mirror off my truck hole thing just unbolted off the door played hell with finding that hole thing last time gonna bolt the next one with nuts this time
Old Nov 27, 2010 | 10:08 PM
PapeCAT's Avatar
This is wrong.
There were improvements made to the 1992/1993 D250/350 Upper Control Arms. Mine broke on the 1989 D250 I used to have on the aft side joint that mates to the frame. I had set of front end parts from a 1992 laying around and noticed that the upper control arm had a doubler in the area where my '89 had broken. Also it was heavier overall.
I then confirmed with Mysteryman that they had re-engineered these arms due to breakage.
Unless you want it to break again I recommend sourcing the 4000 lb front end A arm from a 92/93.
