3rd times a charm: Pulling tranny AGAIN to track down a vibration
Old Dec 10, 2010 | 11:20 AM
Subliminal's Avatar
Hey folks,
So, it took me a little over an hour this time, but the tranny/transfercase/crossmember are all sitting on an ATV jack back by the rear axle.
I've had a vibration since I did my swap. Not 100% sure it's in the clutch area, but it makes sense.
I was hoping you guys could throw some things to check at me while I have it apart.
Things I know to check:
Input shaft on tranny isn't sloppy (check)
Pilot bushing looks ok?
Flywheel is flat and round?
Pressure Plate is good?
Engine Adapter plate is on straight?
Not really sure how to check the adapter plate, but I think it was Phillip made that sound pretty important.
Anyway, anything anyone can throw out at me to check would be a great help. I wanna put this back together tomorrow AM, so I've got some time to tool around out there...and I DO NOT WANT to do this a 4th time.
Old Dec 10, 2010 | 11:32 AM
Subliminal's Avatar
Also, and this may be unrelated...but I just started the truck and it's like 30 degrees outside (truck is dead cold) and my fan is spinning full-tilt. Should the fan be on like that?
Old Dec 10, 2010 | 01:19 PM
d22019's Avatar
My fan runs full blast when its cold until I drive it about a block. My fan clutch is new so i'm guessing thats normal behavior.
Old Dec 10, 2010 | 01:27 PM
Subliminal's Avatar
Roger that...thanks.
Almost have it back together...switched out pressure plate and seems to be better...everything else looked good.
Stupid alignment and reconnecting the trans to the engine is a pain in the nuts!
Old Dec 10, 2010 | 02:20 PM
Subliminal's Avatar
And it's mated back together. Whew. I hate that part!
Unfortunately I can't get it all the way together and give it a test until tomorrow. Stupid work...always getting in the way!
Old Dec 11, 2010 | 11:16 AM
Subliminal's Avatar
So, I ended up putting the original Sachs back in, clutch and pressure plate.
Good news: The vibration is totally gone.
Bad news: The clutch slips.
Old Dec 11, 2010 | 11:42 AM
Wettstein's Avatar
that sucks man. who did you get the "newer" clutch from, if you dont mind me asking?
Old Dec 11, 2010 | 12:37 PM
Subliminal's Avatar
It was a Luk 13"
Old Dec 11, 2010 | 12:43 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
Time to call South Bend? lol
Subliminal
Nov 15, 2010 02:58 PM
CTD2001
Aug 22, 2009 10:03 PM
pwrtripls1
Apr 9, 2008 10:48 AM
csramsey640
Aug 30, 2005 01:13 PM
