3k+ engine vibration
I've got an engine vibration at 3k+ rpm's. Any gear, any speed, even parked in neutral, although its worse in gear than when in neutral. Any ideas or is this normal? I wouldn't think that its normal though.
Thanks, Aaron
Thanks, Aaron
Its not a misfire, or breaking up, it just vibrates the whole truck. Kind of like unbalanced tires doing 80mph.
It could be motor mounts they look OK but its really difficult to get a good look at them.
Oh and i have the "60lb" valve springs, both intake and exhaust.
The injectors are new piers units with less than 10k miles on them, so I doubt it would be the injectors but anything is possible. I was thinking more towards the injector pump. Could that be the issue?
Thanks for the thought, that had crossed my mind, I checked the fan and it is solid, as far as the clutch and bearing. I will double check that all the blades are secure though.
bad lift pump not delivering enough fuel to the IP?
My truck would vibrate through the pedal for some reason (near WOT or near 3k) and it stopped after a new lift pump.
Just a thought from a total mechanical rookie.
ahh yes... me grasshopper!
