350/250 bed question?
Old Nov 6, 2012 | 12:52 PM
Necred's Avatar
Just wondering? If i decide to change my D350 to single wheel 350, would i need to find another bed, is the cut of around wheels larger on 350? I am assuming i can find a rear housing to replace mine with...
Old Nov 6, 2012 | 01:49 PM
simplysmn's Avatar
the only bed that's different is the DRW bed everything else is same
Old Nov 6, 2012 | 01:52 PM
Necred's Avatar
ok, so,
to change to single rear wheel i would need to change beds also..
Old Nov 6, 2012 | 01:55 PM
simplysmn's Avatar
Yes unless you just want to leave the wider fender on there .If the fender's are any good you could alway sell them or just cut them even with edge of bed it will give you a Bigger opening is all with stock tires it would look kinda funny but still work
Old Nov 6, 2012 | 03:48 PM
Necred's Avatar
that was my concern, if the wheel openings were noticeably larger on 350 than 250. I was actually looking for 250 when i bought this one. I wish i had kept looking, 350 is tight squeeze in parking area..
Old Nov 6, 2012 | 05:12 PM
simplysmn's Avatar
the only thing different is the dually bed has a bigger opening you can put a srw bed and axle on your truck and nobody would tell the difference .
Old Nov 6, 2012 | 07:08 PM
Necred's Avatar
yeah, i have access to axle but not bed, as of today.
Old Nov 6, 2012 | 08:40 PM
simplysmn's Avatar
well if you wern't on the east Coast I have 3 bed's to choose from .
Old Nov 6, 2012 | 10:53 PM
jimbo486's Avatar
The only difference between the SRW and DRW beds is the wheel well opening is much larger on the DRW beds to accommodate the fenders and still have clearance for tires. The physical size of the beds are the same. Also, the dually axle itself has a wider track width than a SRW axle so your tires would stick out a bit.
Old Nov 7, 2012 | 11:11 AM
james1's Avatar
Smile
Keep an eye on e-bay. About 4 years ago I purchased an excellent used bed for about $225 on the Mississippi coast (a one-day round trip from Atlanta). I had been monitoring e-bay for roughly 12 months before I finally found what I needed.
Old Nov 7, 2012 | 06:02 PM
Necred's Avatar
Thanx for info.....Im gonna pass on rear end,,its not something i must do.
NO_SPRK
Dec 5, 2008 06:05 PM
STACKED
Sep 13, 2008 12:19 PM
Common
Aug 10, 2007 10:32 PM
guh2stroke
Dec 24, 2005 08:45 PM
widetrak60
Nov 7, 2005 12:19 PM
