3200 RPM Governor Spring
thats because it is just a spring out of a marine pump or some other pump that happens to have a 3200rpm defueling point, someone just did some research to figure this out. So you are kindof ordering blind, but you just have to trust the good people on this site who have done this research!
Originally posted by Blowndodge
Someone earlier posted the spring part number. Here's the problem: I call a certified bosch diesel shop and they said that was a valid number butttttttttttttt......it doesn't tell them what that part number does!!!!! In other words, it's a spring but doesn't give the rpm range or anything else. I hate to be ordering blind like that but I went down there and saw that bosch doesn't tell what the rpm range is. Weird but true.
brad
brad
the spring # i used is 1464650366..i was one of the first. it took me months to get bushy to try it. ask him. the simple things do more for our trucks than any of the complicated and expensive things do. i do not know anyone on this board that would steer ANYONE wrong about what makes these trucks come alive. the spring cost me 15 bucks from cummins.
Jughead is correct, it did take some time to convince me to try this mod....my hesitation was based on the facts that it was not widely used and no "volume" of assessments/data/results and, most of all, the nervous factor....that is probably the single biggest factor to making more "in depth" changes when it comes to these pumps/trucks.
I will say, that once the change was made I was very please with the results...it helps to hold/pull heavier fueling levels right up to the physically governed limits as set by the governor screw and has greatly reduced the influence of the governor counterweights in the pump to pull the fueling back.
pb....
pb....
Originally posted by pwrtripls1
If the 3200 is not enough I have a VE spring in my marine pump that is for 4600rpm defueling. That is if the cummins will hold up to that.
Well in the MD41 Volvo diesel I rebuilt it for its set to defuel at 4600rpms. If you keep pushing it it will sometimes slowly get up to 4900. I wonder id there is any other difference in the marine pump and stock cummins.
At least i have a pump to tear down and try things with before i do it to the one on the truck.
I would just swap the gov spring over, but i dont want to over rev this old motor and blow it.
even a pump # would be good. could take that to a bosch shop and they'll be able to get the spring for it. and you wouldn't have to listen to the old "well, THAT won't work. prolly shouldn't even sell it to ya" routine.
this could get interesting.
