2wd convert to 4wd or strait axle???
Old Feb 14, 2008 | 12:11 AM
Dub-D250's Avatar
i hav a 89 D250 cummins 2wd and after looking around have found that theres really no good way to get any height outta the truck so, only ideas are find a strait axle setup or just convert the whole thing over to a 4wd setup. wondering what would be the best route to take, anyone done it befor? whats a good axle to put in the front? anyone know if a front end off a 4wd 1st gen will fit right up with a lil fab work done?
any help, advice or sites that help would be great thanks
Old Feb 14, 2008 | 12:19 AM
mullishacrew's Avatar
you will need a dana 60, a np205 transfer case or anything close to that custom crossmembers, possibly a transmission to hold the transfercase depending if it's it's and auto or not manuel u could get an adpater for the transfercase, then you will need the steering setp up from the dana 60 whitch should come with it, shakles for the rear and front mounts for the leafs, it will be a big jog and aint cheap for the dana 60 or np205 they can get pricy inless someone dosent know what they are selling.
Old Feb 14, 2008 | 12:58 AM
GLHS's Avatar
A fellow just did this swap a few weeks ago on pirate4x4 in the Dodge section.
Old Feb 14, 2008 | 09:31 AM
C/PRD/'s Avatar
Here ya go>http://www.cumminsforum.com/forum/89...ere-we-go.html
Old Feb 14, 2008 | 12:26 PM
BearKiller's Avatar
If you just want a better front axle/suspension, you can install the 4x4 front axle without a transfer-case.
If desired, you can even gut all the gears, axles, etc., leaving only the housing and hubs.
Old Feb 14, 2008 | 12:30 PM
1-2-3's Avatar
Just a plain ole guy
Take your cab, nose, and bed and set it on a newer 4X4 frame.
Old Feb 14, 2008 | 03:17 PM
PapeCAT's Avatar
yah great but who has those lying around lol
93Fury
Mar 31, 2010 01:33 PM
Jordan5687
Feb 18, 2009 02:48 PM
RobV2500
Jan 21, 2009 09:22 AM
ridofpwrstroke
Aug 25, 2006 05:24 PM
1320
May 6, 2003 06:30 PM
