2 speed
Old Jan 2, 2008 | 09:40 PM
honest outlaw's Avatar
2 speed
howdy everybody i was talking with a brother at my last lodge meeting. telling him about the '90 ctd i had aquired at a very reasonable price i mentioned to him that the 727 tranny shifted to drive at about 40 to 45 mph and that i was considering changing the rear end to boost speed and help mileage. he then told me about a 2 speed gear box that drag racers sometimes used so they could drive a very low geared car at road speed without turnig 7 grand. so my question is, has anybody ever had any experience with this ? if so will this devise stand the strain of trying to pull heavy loads ? is it cost prohibitive ?do they even make one that will work on this truck ? how bout it ?
Old Jan 2, 2008 | 09:59 PM
Onemoparnut's Avatar
gear vendors overdrive
Old Jan 2, 2008 | 10:21 PM
1stGen545's Avatar
they use them in big motor homes.
Old Jan 2, 2008 | 11:01 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
They do make them for your truck and they say they will handle 1000 horse
Thats what I've been told
I'm sure someone will chime in if i'm wrong
Old Jan 2, 2008 | 11:07 PM
Micaiahfied's Avatar
so my question(s) is(are), has anybody ever had any experience with this ?
Yes, there are several people on this forum that have a gear vendor overdrive in thier truck
They are amazingly strong, I've never heard of someone breaking one due to a heavy load, in fact I don't think I've heard of one breaking
Yes, I would have one if they were not upwords of $2000 or more, I can't even remember...
Yes, I believer there is one for each tranny and one made for the NP205 transfer case, someone correct me if i'm wrong
how bout it ?
hope this helps...
needcharatersoutsidethequote
Old Jan 3, 2008 | 01:00 AM
farmer0_1's Avatar
dad has one on his 4x4 87 chev four speed diesel has a good 100k on it with little issue. his pickup has 410 gears sure helps to split all the gears on a good grade. his is a us gear and yes fifteen years ago it was close to 2k installed.
Old Jan 3, 2008 | 06:58 AM
therabbittree's Avatar
the two speed the drag racers use is a chevy powerglide transmission..not what you'd want in your truck..if I was you , I'd up grade to a 47 RH...and have 4 speed auto with lock up converter...
Thanks
Deo
Old Jan 3, 2008 | 11:45 AM
mhuppertz's Avatar
The Gear Vendors unit is unbrakeable (if you keep oil in it!), and they do make one that fits the NP205 because that's what I have.
Mine had the OD clutch out, the last owner let it leak dry.... saving up for the rebuild...
Drag racers use them a lot.
Old Jan 3, 2008 | 04:50 PM
olddodgetrucks's Avatar
i had a ihc one ton 392 5 sp od 2 speed rear axle last of the ihc trucks under 3 tons wished i would kept the rear axle,was called a gooseneck special.
Old Jan 3, 2008 | 05:20 PM
G1625S's Avatar
Now that truck would be cool to see
Old Jan 3, 2008 | 05:29 PM
G1625S's Avatar
Just did a little research. It was an Eaton axle with 12k capacity!
Available ratios:
5.14/7.15
5.83/8.11
6.33/8.81
Lubrication:
Spiral Bevel Planetary
Axle shafts:
1 3/4''. 16 spline
Ring gear:
14 1/4''
Old Jan 3, 2008 | 05:57 PM
They put that under a 1 ton?
Old Jan 3, 2008 | 07:17 PM
mhuppertz's Avatar
That was a great truck, the 392 got 8mpg whether pulling a house or free falling down a mountain!
Old Jan 3, 2008 | 07:20 PM
G1625S's Avatar
You've gotta have Adobe Reader and you need to rotate the file 90*, or jsut tip your head, but here's the breakdown I found:
http://mail.telebyte.com/allanw/bind...s/rearaxle.pdf
Old Jan 3, 2008 | 07:34 PM
mhuppertz's Avatar
The fastest Diesel digger right now (ATS in the 7's) uses a PowerGlide AND a Gear Vendors.
