2.5" rear lift
Old May 31, 2003 | 11:37 PM
cah's Avatar
cah
2.5" rear lift
When I bought my truck I noticed, like some of the other 4*4’s, it sat low in the rear. I found a kit at a local 4*4 shop that was a perfect fit. It’s contained bigger blocks for the rear with longer u bolts. I had the old bolts cut and replaced the factory 2.5” blocks with the new 5”. The guy at the shop had never sold the blocks for a dodge before and wasn’t sure if there would be a vibration from the shortened drive shaft but It seems just fine. My truck now sits just a bit higher in the rear. I think it looks allot better.
Old May 31, 2003 | 11:43 PM
bigredbrick's Avatar
Re:2.5" rear lift
Blocks aren't the best way to go - springs would be better. Blocks are a whole bunch cheaper tho. FWIW my '93 came from Mother Mopar with big ol' hangin' blocks.<br>Chris
Old Jun 1, 2003 | 12:03 AM
powerwagon440's Avatar
Re:2.5" rear lift
just like the BRICK said blocks r not the best. i have a 83 4x4 that had the blocks on there granted it has 8 inch suspesion lift but evertime u took of u could feel the rear end move after a few months of driving all the time the blocks had moved 2inches and was ready to fall out so i went to a skyjacker spring very very nice! rear end doesnt move now.
Old Jun 1, 2003 | 12:08 AM
Re:2.5" rear lift
Some years ago I was behind a severely lifted Toyleta with big blocks in city traffic. Everytime he took off that pinion would rotate drastically up towards the bed - kinda hard on u-joints!
Old Jun 1, 2003 | 12:17 AM
Re:2.5" rear lift
ya those blocks ruined my drive shaft and plus the rear end wasnt turn up and has serverly wore the yoke!
Old Jun 1, 2003 | 12:27 AM
Re:2.5" rear lift
I think the factory springs on the CTD are stiff enuf where it might not be as much of an issue. It hasn't been a problem on my truck yet and I do have a heavy right foot.
over &amp; out
Old Jun 1, 2003 | 12:33 AM
cah's Avatar
cah
Re:2.5" rear lift
Well now that youve got me worried, has anyone run this setup in a stock 1 gen
Old Jun 1, 2003 | 12:36 AM
cah's Avatar
cah
Re:2.5" rear lift
Sorry, didnt see the last post. thanks
Old Jun 1, 2003 | 12:40 AM
Re:2.5" rear lift
i would think u should be ok with what u have now 5inch block right? but i wouldnt go any higher with blocks. u have a camper package with extra springs? my 91 i just bought has to sets of springs on the rear i assumed it must have been a camper package? my 93 doesnt have the extra springs<br>
Old Jun 1, 2003 | 05:59 PM
cah's Avatar
cah
Re:2.5" rear lift
are u talking like an overload leaf spring?
Old Jun 2, 2003 | 04:06 PM
Alec's Avatar
Re:2.5" rear lift
I thought that the later trucks ('92 or '93) had taller blocks from the factory. I have been idly planning on trying to get a set of blocks as tall as the later models . . . If it was good enough for the factory, I figure it is good enough for me, at least in this instance.<br><br>Alec
Old Jun 2, 2003 | 05:01 PM
cah's Avatar
cah
Re:2.5" rear lift
Well I have now talked to 2 different people with 5&quot; blocks and they have had no problems. Both have over 80000mi with the switch. Hope I have the same success!
Old Jun 3, 2003 | 11:52 PM
apache's Avatar
Re:2.5" rear lift
One of the major concerns when running tall blocks is also the leverage placed on the entire assembly with reguards lateral movement. the possibility of the block rolling out. CTDs are able to haul big loads adding to the stress. this is why blocks are illegal in the front of a vehicle, when hard cornering takes place the potential to collaps is present. I have yet to see this happen but if quality U bolts etc are not used????. You can fabricate or purchase a Kicker type set up to slow the axle roll under hard pedal use. but for the lateral movement a panhard type rod would be necessary.<br> Good luck.
roughstock
Nov 2, 2013 01:48 PM
Tank_66
Jul 17, 2009 06:54 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
