1st gen no heat in cab
Old 12-04-2019, 12:22 PM
fremec's Avatar
92 dodge cant get no heat in cab,if there is its very little,changed water pump and new thermostat 8 months ago,still no heat build up.My buddy has same truck as mine and he has lots of heat,he never touched his,could my heater core be plugged?
Old 12-04-2019, 12:25 PM
Received 2,388 Likes on 1,576 Posts
I would first check that your thermostat is actually working.
New parts don't always mean good parts.
Does you truck have a working temp gauge? Does it read that it gets warm?
Drilling a 4 inch hole in the inside of the heater box, cleaning out the debris, then installing a marine deck plate on my 1st gen trucks is a standard thing I do to them.
Old 12-04-2019, 12:28 PM
Fordzilla's Avatar
The way to test is with the engine thoroughly warmed up, upper radiator hose hot and heater control moved to full heat, are both heater hoses, supply and return, hot?...If so the core is clear......Ben
oliver foster (12-04-2019)
Old 12-04-2019, 02:08 PM
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
On my truck which is an 89 model there is a vacuum operated valve in series with one of the heater hoses just before they attach to the heater core. Have you checked to see if vacuum is getting to the valve?
Edwin
corn binder
11-24-2008 08:44 AM
Canso
09-21-2008 08:45 AM
jj3500
02-07-2008 10:18 AM
lt11le
03-10-2007 06:49 AM
Micaiahfied
02-11-2006 08:48 PM
Quick Reply: 1st gen no heat in cab
