1st Gen intercooler mounting pins problem
Old Oct 28, 2010 | 08:57 AM
JimmieD's Avatar
I posted this over on another forum and want to put it up here too. As mentioned there: I received some great help & advice several times here a few years ago when I was installing a Cummins 4BT in my '67 Dodge Town Wagon. Maybe I can pay back a tiny bit. Some of you may know about this tip already.
I'm installing a late 1st Gen '91-1/2 to '93 intercooler in the same truck above, obviously a custom install. I looked at the I/C and noticed that one of the mounting pins on the bottom of air tank was worn away about 50% on one side. Don't know where these pins go in an original OEM install.
Anyways, got out the MIG, cleaned up the pin with brake cleaner and as soon as I hit the trigger on my MIG gun phzzzzttt, the end of the pin was vaporized!
I had made 2 classic mistakes: one, I ASSUMED these pins were steel by the look of them, and by what I imagined their function must be. Second, I failed to use the welder's best friend, a magnet to check if it's ferrous iron bearing metal or non-ferrous. Guess what? Right....
I'm warning you guys because to look at those pins they look like stainless steel but in fact they're some kinda alloy and can't be welded with a MIG. I can still proceed with my install without them and even end up better off knowing they are not a strong load-bearing piece. On a stock OEM installation maybe this would be a large problem, don't know.
Hope this saves some folks some needless grief.
Old Oct 28, 2010 | 10:25 AM
Onemoparnut's Avatar
The pins are aluminum just like the tanks. Never clean anything with brake cleaner before you weld it. It creates a gas that can kill you fast. Do a google search for welding and brake cleaner and you will find it. I forget what the gas is but I know its not any good for you.
Old Oct 28, 2010 | 10:29 AM
It makes phosgene gas and from what I understand that is nothing to play with.
Old Oct 28, 2010 | 10:38 AM
JimmieD's Avatar
Thanks, Bill!
Correct on the pins, they're machined out of the castings that form the end tanks.
YES!!! on the brake cleaner & MIG welding!!
Thank God it was only an instant of actual welding but that gas, possibly phosgene, puffed off & I inhaled it! Seems funny because it had apparently all evaporated dry so I thought I was perfectly safe: NOT!
Felt like crapola all last night & this morning have some great respiratory problems, one ear all clogged up & swollen gland, sinus problems, aches & pains & feels like a Duesie of a cold coming on! Like you say, coulda killed me.
DON'T TRY THIS AT HOME!!!
Thanks....
Old Oct 28, 2010 | 11:03 AM
You should go see a dr it is nothing to play with at all.
Old Oct 28, 2010 | 12:43 PM
JimmieD's Avatar
Thanks, buddy, your concern is very much appreciated!
I seem to be okay now, and just a single little whiff of it, though I know it doesn't take much at all! You're right again and I may go see my sawbones today anyway.
I have already ended up disabled for life thanks to a previous toxic chemical exposure so I do know somewhat about that haah! Seems it's always the last thing a person ever expects, and too often, it's the last thing they experience in this world...
http://www.bt.cdc.gov/agent/phosgene/basics/facts.asp
Thanks!
onetwopunch
May 17, 2010 10:58 PM
pulltilbroke
Apr 10, 2009 02:08 PM
Trooperthorn
Feb 5, 2008 09:40 PM
tboling
Jul 16, 2006 05:49 PM
Monty
Dec 19, 2004 09:35 AM
