1st Gen blocks
What year blocks are interchangeable with the 1993 5.9 block? Im thinking about slowly building a replacement, so when the time comes, Ill have a fresh replacement ready..
Just the lower end block is the same '89-'98.0.
If you also mean with the head on it as well, then the head is different '89-'91.0 than the '93 head. In '94 the injection pump and injectors change, so the later heads would need the injectors swapped. |
Oh and if you need a Cummins 12V motor, I have dozens of them in my shop.
Oliver, how's it going? I recall something about a Brazilian casting that was inferior, is that true?...Mark
It is going great!
Yes there is a Brazilian block known as the 53 block. I usually see them on the 24Vs. |
(Post 3362406)
