1st gen 3" brakes
Old 03-08-2005, 01:14 PM
darkvader's Avatar
1st gen 3" brakes
I can't find the thread on converting 92 w250 to 3' brakes need part numbers for wheel cyln and shoes please
Clark
Old 03-08-2005, 02:10 PM
Dan Brooks's Avatar
Raybestos 314PG - 3" rear shoes
Raybestos WC36057/WC36058 - wheel cylinders for conversion to 3" brakes
Old 03-08-2005, 02:19 PM
darkvader's Avatar
thanks Dan, but does anyone have the napa numbers, counter folks at napa can't seem to cross raybestos number
Clark
Old 03-08-2005, 02:31 PM
jiMMyCTD's Avatar
ts358
Old 03-08-2005, 03:54 PM
Den
Den's Avatar
Use all the same spring hardware and hold downs?
Den
Old 03-08-2005, 04:58 PM
Dan Brooks's Avatar
Den
Yep. The only things I changed were the shoes and cylinders.
Old 03-08-2005, 05:11 PM
Den
Den's Avatar
I'm goin for it!
Den
Old 03-08-2005, 05:27 PM
Dan Brooks's Avatar
If you don't have one already, this is a huge help with the hold down springs:
http://www.etoolcart.com/index.asp?P...OD&ProdID=2241
This is a big help with the other springs - much easier than trying to use a pair of pliers:
http://www.etoolcart.com/index.asp?P...ROD&ProdID=374
Old 03-08-2005, 05:40 PM
Thanks Dan! None of the local parts stores had that tool, so I made a lousy substitute. It got the job done (barely), but now I'm gettin' the real thing!
Old 03-08-2005, 06:11 PM
Den
Den's Avatar
Me too! I ordered both and got the heck outta there! A tool site...that's a dangerous place for me to be wandering around
Den
Old 03-08-2005, 09:19 PM
spunbearing's Avatar
The napa part numbers I found on an old thread here are as follows.
wheel cylinders 4636057 and 4636058
shoes TS-358
You might want to double check the shoes. I had a friend install mine and he said that they were the same size as the ones I already had. So either I already had the 3 inch shoes or it could be the wrong part number that someone posted. I wish my friend would have called me to come look at them before he put them on so I would know for sure.
Old 03-09-2005, 08:53 AM
darkvader's Avatar
Thanks all
Clark
Old 03-09-2005, 09:04 AM
greatwhite's Avatar
TS 357 originals. 2.5"
TS 358 the 3"
Old 03-08-2007, 09:29 PM
1st Generation Admin
BC847's Avatar
Question Reviving an Oldy-But-Goody
I'm fixing to work on the brakes this weekend and checking availability, my partsman says there's three different rear wheel cylinders listed . . . . as you most likely know. He quoted numbers such as the smallest might have been 5/8" bore, a middle size, and the largest was 1 1/8" bore. (I'm working from a cloudy memory).
At the time, I'd not checked "The Sticky".
Anyhoot, I suppose I can ask him to use/cross the numbers found in this thread.
Does anybody know what the OEM rear wheel cylinder bore is, and what the upgraded bore is?
As it stands, I can't find a reference just yet in the FSM, and I've not torn down the truck to confirm what's there ('93 CC W250) . . . .
Can anyone sum up the latest part numbers and bores?
Old 03-09-2007, 07:54 PM
1" (Bendix 3304 & 3305) on 2.5" brakes and 1 1/8" (33206 & 33207) on 3" brakes. I find that the 3" brakes and 1 1/8" cylinders are very effective on my truck.
Quick Reply: 1st gen 3" brakes
