1993 D350 wiring harness
I fried the wiring on my 1993 D350 Diesel Automatic. Shop told me to scrap it because they could not find replacement harness. Hope some of you can help. Anyone know what else is compatible? Local junk yard has a 1991, anyone know if harnesses are the same? How about D250 instead of D350 of same year? Lastly, anyone have a wiring diagram they would be willing to post?
Go buy a bunch of different colored wire spools. Grab a piece of paper and just start running a wire at a time and make your own diagram for future references. That's about the best I have figured for my trucks wiring mess.
The harness from a '92 or '93 diesel will work. D or W, 250 or 350, makes no difference.
Sent from my Paranoid Android HD2 using Tapatalk 2. |
Which harness did you fry? There's a engine, dash, door, cab and chassis harnesses. Also auto and 5spd trucks use the same dash harnesse and only slight differences in the chassis harness
Originally Posted by gyman98
(Post 3109033)
Faith, is this a no to the 91 or just that you know 92 will fit a 93. Thanks for the help. |
harness
Originally Posted by EdParker
(Post 3108985)
i have a 1993 d350 engine harness
Originally Posted by Donald Gleason
(Post 3356804)
I have one of those harnesses to, but I am guessing he has fixed the problem, or sold the truck, as this thread is about 7 years old. Welcome to DTR anyway, Donald. |
do you know of anyone with a 1992 d250/350 cummins engine harness
(Post 3356811)
Or try car-part.com.....they link 1000's of junkyards.
(Post 3356804)
(Post 3356803)
I have a 1993 engine harness
(Post 3356805)
I have every wire harness for a '92/'93 Cummins truck.
Which harness do you need? Engine bay? Engine harness? Dash harness? PM with your details. And the earlier questions about '91 harnesses...yes the 91.0 is different that the 91.5 harness, which are both different from the '92/'93 harness. The '89-'90 harnesses can be interchanged. So that said, there are 4 different engine bay wire harnesses for the 1st gen Dodge Cummins trucks. |
(Post 3371022)
Which harness do you need? Engine bay? Engine harness? Dash harness? I'm not sure can you email me directly Firehydrant404@yahoo.com I think its the engine harness its the one with two big plugs and hooks to the injector pump and other sensors. PM with your details. And the earlier questions about '91 harnesses...yes the 91.0 is different that the 91.5 harness, which are both different from the '92/'93 harness. The '89-'90 harnesses can be interchanged. So that said, there are 4 different engine bay wire harnesses for the 1st gen Dodge Cummins trucks. |
