1992 d350 fuel leak
Old Jan 24, 2012 | 11:52 AM
davidmiller4747's Avatar
1992 d350 fuel leak
Going to remove the fuel heater n replace the o-ring. Any advice? Going with the Fleetguard fs1251 filter. Is there anything wrong with leaving the Water In Fuel sensor out?Also, need to replace the rubber booty on the tranny for the clutch; Q. Can i replace the rubber booty easily and does anyone know the part #? I do not like going down the road knowing that debris is getting in there because the old one has fallen out! Thank you for your help!
Old Jan 24, 2012 | 01:48 PM
jimbo486's Avatar
I can answer the question about the fuel filter. There's nothing wrong leaving the WIF sensor out. Since the FS1251 has a valve in it, it would be ideal to open it every so often to check for any water that may be present.
I'm not sure I know what rubber boot you're referring to.
Old Jan 24, 2012 | 10:37 PM
the rubber boot on the clutch fork lever sticking out of the drivers side of the tranny
Mar 27, 2012 10:14 AM
Jammie Dodger
Aug 15, 2009 12:38 PM
jcb
May 21, 2007 05:49 PM
norillidavis
Oct 9, 2006 08:48 PM
jcb
Dec 19, 2005 01:27 PM
