Front inner axle seals?
Old 02-01-2012, 09:48 PM
bryson711's Avatar
Does anyone have part numbers for the inner axle seals? Also do the install from the inside of the housing? Or do you install them from the axle tube side?
Sent from my DROID2 using Tapatalk
Old 02-01-2012, 10:20 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Installed from inside the axle, special tool needed. You could possibly fabricate tool with all thread rod, nuts and large flat washers. Seal is then pulled into housing from inside until seal bottoms in bore.
Old 02-02-2012, 06:57 AM
Philip's Avatar
I use my snap on whell bearing retainer nut socket. It fits the seal perfectly for install. Just use a real long extension for the short side of the axle.
Old 02-02-2012, 07:17 AM
bryson711's Avatar
Ok so im a little confused I guess, can you not just tap the seals in the the inside of the housing where the gear set is? I have a arbor and different attatchments for different size seals. To tap them in with a hammer. I have the gear set and all the axle shafs out.
Old 02-02-2012, 07:33 AM
Philip's Avatar
The room for a hammer inside the center section leaves very little room to apply much driving force.
If you can get outside of the housing with the hammer it is easyer to drive the seal in.
Old 02-02-2012, 07:44 AM
bryson711's Avatar
Ahh ok I see, alot less confused now! I will see what I can do tonight, thanks for the help! Also when getting the old ones out did you just use a long pipe and go from the kingpin side of the tubes and pound them out?
Old 02-02-2012, 10:16 AM
Philip's Avatar
I just used the 3' long- 1/2" to 3/8' drive extension I have. For driving out. Anything long enough will work.
shackwrrr
07-27-2015 06:29 PM
cougar
10-07-2014 07:40 AM
Buckshotram
14
07-22-2008 01:34 PM
big stinky
06-11-2008 06:56 PM
Baja
03-05-2008 01:11 AM
Quick Reply: Front inner axle seals?
