1990 Dodge Body Parts
Old Jul 7, 2011 | 12:28 AM
clark4020's Avatar
Are 1990 and 1992 fenders the same even with the different grill?
Old Jul 7, 2011 | 12:51 AM
9MM's Avatar
9MM
Yup hoods arn't though they will interchange to just the 91.5-93 didn't have dodge on the front of the hood but yes fenders are the same.
Old Jul 7, 2011 | 12:59 AM
simplysmn's Avatar
Hood's are same all the way from 81 to 93
Old Jul 7, 2011 | 01:12 AM
9MM's Avatar
9MM
My mistake I forgot the dodge emblem on the non intercooled trucks had double sided tape not two holes and clips.
Old Jul 7, 2011 | 01:33 AM
Thiss's Avatar
In Short: yes
Dodge Sweptline Pick Up Interchangeable Parts W100-W350 D100-D350
Cabs
1971-1993 All Standard Cabs
Check firewall and transmission (2wd Auto, 2wd Man, 4x4 man, 4x4 Auto) tunnel changes
1973-1982 Club Cabs
1972-1985 Crew cabs
Check firewall and transmission (2wd Auto, 2wd Man, 4x4 manual) tunnel changes
Windshields
1971-1993
Hoods
1971-1980
1981-1993
^hood emblem discontinued after 1990
Doors
1971-1980
1981-1993
^fold away mirrors 1988
^full length door panel?
^Vent window and gasket change sometime after 1985
1991 front doors on 85 cab
1985 doors on 1991 cab
1973-1985 Crew Cab rear doors
Fenders
1971-1980 (check two-tone with vs basic paint)
1981-1993 (check two-tone with trim LE vs. basic)
^inner fender added an extra rib between 85 and 91, but still bolts up
1985
1991
Beds
1971-1980 Short and Long
1981-1993 Short and Long
Tailgates
1971-1980
1981-1993 standard
1991-1993 LE
Core Supports
1971-1993 All will bolt in, however numerous changes to headlights, grilles, and most importantly for diesels intercooled or non
1981-1985 (honeycomb grille)
1986-1990 (cross hair grille)
1991-1993 (cross hair chrome grille with intercooler)
For more info check
http://www.pickuptrucks.com/html/history/segment10.html
Old Jul 7, 2011 | 01:40 AM
Thiss's Avatar
Dodge hood emblem was used from 1981-1990
They all, I believe, had the two holes. But one can always fill, or drill, holes
Fender badges too changes in 1991, however double stick tape is used and the previous provisions are covered.
I will add pictures later. There is a sweet 70s two tone down the street with a two tone bed, too bad they moved the trim.
Oh and tail lights, 81-93 again check chrome bezel versus black
Old Jul 7, 2011 | 07:20 AM
All the badging and molding changed in 91 not in 91.5..
It all changed with the new front end .
Old Jul 7, 2011 | 09:03 AM
Thiss's Avatar
Edits made, thanks. If anyone else has more edits let me know. I just want to get all the body changes out there finally. I flat did not know you could get a non intercooled with the newer grille and molding.
Old Jul 7, 2011 | 09:23 AM
clark4020's Avatar
92 fender fit on 1990
i know that the molding is different in 91 92 93 but they are the same body lines and will fit the 1990 grill?
Old Jul 7, 2011 | 09:29 AM
Thiss's Avatar
Yes, you can use a 92 on a 90. In fact you can use any fender from 1981-1993.
Old Jul 7, 2011 | 01:14 PM
clark4020's Avatar
Thanks man
Old Jul 7, 2011 | 08:00 PM
NE frmhnd's Avatar
The bed mounts change a little during the run, you may need to either move them, or just drill a couple new holes.
Old May 20, 2012 | 01:45 PM
elymorrison's Avatar
Can I use the one piece 91-93 grill on my 90 W250 without modifications? I'm having an extremely difficult time finding a new grille shell for mine.
Old May 20, 2012 | 03:28 PM
jerseybud's Avatar
Door strikers and corresponding latch changed for the 1986 model year. Easy to change out if you know about it before hand
Bed mounting changed in btw 1989 and 1990 model years (and the frame also) as scot pa said
The doors have been the trickiest to nail down when the changes were done. It seems the 1987 and later doors are much more flimsy b/c of the new venting near the front hinge. (The 93s had these vents covered with a vinyl patch) This was about the time they went to the full length interior door panel. Some people state that the sheetmetal is much thinner on the 87 and later doors as well.
I've also noticed 2 different vent window gaskets from the factory: One that has a extension towards the rear that prevents more water from getting in the door and one that ends right at the divider between the vent window and side window.
And No you cannot use a 91-93 grille on a 90 without modifications or not using your headlight bezels
Old May 20, 2012 | 03:44 PM
Thanks! Do you happen to know what it would take to make it work?
