1989 ABS Hyraulic Unit
I'm Looking for a 1989 ABS Hydraulic Unit to have rebuilt. Would anyone have a old unit laying around the shop/garage?
Would that be the dump valve in the back for the RWAL system? If so that's what's wrong with mine. I didn't know they were repairable.
A1-Cardone will reman the ABS Hyd Unit (Dump Vale); their part number for the '89 mode is 12-2014. If you choose to have it repaired, you must send it in thru a A1-Cardone vendor under the R&R program. Core unit has to repairable.
Mine resides in the scrap pile.
I have one somewhere in my garage. The problem is that I am in Mexico now and I am not sure that I am coming back. If I do, I'll look for it for you. I would have to eventually come back to liquidate all my stuff and sell my house. I might even take 20k for my Impala...Mark
Originally Posted by JPrewitt
(Post 3315264)
I'm not sure just how valuable this system is. I've never been impressed with ABS. I figured that it just makes you able to keep your vehicle straight as you hit whatever you're going to hit anyway. I figure if it's to slick to get going then you should stay parked in your driveway. I had an accident once when my ABS unit decided to pump my brakes when if I had locked my wheels I would have stopped shorter and not hit. This was on dry pavement. Edwin |
(Post 3315289)
I just looked on O'Reilly's web site and they show the price at $188.99.
Maybe368, I think your right about the O'Reilly's comment. At least that's what I found at AutoZone and O'Reilly's, you have to use the R&R program. As for searching for your removed unit, thank you, but unless it's off of an 1989 D/W250 or 350, it will not do me any good! The 89's were the only year that used this part number! It's like looking for a needle in a haystack! I guess Dodge figured out there was an issue and changed to a different unit in the 90's.
(Post 3315325)
Edit: Here is a pretty good description of the valve: Kelsey-Hayes RWAL Antilock Brakes |
I have been trying to get people to send me their units, but they would rather throw them in the trash. Yes, they can be repaired if the only thing they need is new seals. I've done it.
Originally Posted by cougar
(Post 3315335)
Not long ago I took my 2nd gen starter in for OH. The shop wanted to exchange it for a China unit. NO! But it's cheaper. NO, NO, NO!!!! They finally got the hint.
(Post 3315383)
