1985 w-350 axle
Old Aug 4, 2007 | 05:17 PM
bek's Avatar
bek
1985 w-350 axle
I found a 1985 w-350 in a bone yard today with a massive dually rearend. Can you experts tell me some thing about it? Is it a Dana 80 and would it fit on a "95" as far as axle length? I realize shock mounts would have to change and probably other things. Dually rearends are practically non existent in New England. Any info appreciated. Thnx Steve
Old Aug 4, 2007 | 05:34 PM
simplysmn's Avatar
I would not use it I dont believe it's a dana 80 back in the 80's I thought they only had the dana 60 or maybe even a 70 rear .?and Please correct me if I am wrong .
Old Aug 4, 2007 | 05:55 PM
bek's Avatar
bek
It looked like it was set up for dual wheels, I could be wrong. Was there a Dana 70 dually?
Old Aug 4, 2007 | 06:00 PM
rbrettctd's Avatar
Before the diesels the driveline was not so stout. Like he said, could be 60 or 70 dually, or some sort of chrysler axle.
Old Aug 4, 2007 | 06:57 PM
mullishacrew's Avatar
as for bolting up, my truck has a 94 rear end under it and it bolted up with the shocks relocated using the shock mounts that get bolted up with the u bolts and my trucks a 93.
Old Aug 4, 2007 | 09:51 PM
bgilbert's Avatar
Most likely it's a D60.
Old Aug 4, 2007 | 10:00 PM
dodgenstein's Avatar
Dodge duallys had a Dana 70 rear axle since way back in the sixties. The only drawback I can think of is, the high geared ones were 4.10s and some had 4.56s or 4.88s.
Old Aug 4, 2007 | 10:03 PM
bgilbert's Avatar
True, but it had to be ordered that way. Most likely it's a D60 dually. I have two D60 dual rear ends in my yard with 3.54 gears.
SUPRDUD
Aug 18, 2008 12:02 PM
dieselsmoke12
Cummins Conversions
May 23, 2008 08:22 PM
rootercycles
Nov 10, 2007 06:28 PM
mullishacrew
Oct 8, 2007 04:00 PM
winkle
Oct 14, 2005 12:01 AM
