14mm pump preview....
514whp is a very impressive number! Cant wait to see what the final numbers turn out to be.
Was that dyno with just the 14mm and turbo over the last dyno, or did you advance the timing too?
But how do you like that setup? I was thinkin about goin that route. And you run that thing at 30 psi???
I thought you could only run it 16 to 20 psi even with loctite on the front seal? I'm curious to see what your trucks got.
Good luck man.
Still not that much timing, pump is bumped almost to the head, but not quite. I think about 20-ish degrees total. Going to the dyno again soon with a bottle heater and see if I can't do a little better.....
Am I thinking wrong or missing something?
i agree with you pwrtripls1 something is wrong that thing should be rolling out some big numbers my short bed single turbo and some big injectors all fuel put down more hp then he did
JQ you got your dyno sheet i like to see it..
I could see your fuel only being low, the IAT has to be extremely hot, plus the tiny crossover pipe has got to be holding the turbo back. But the N2O cooling the charge and adding alot of oxygen should get you to 600+whp. Was your dyno graph fairly steady, or did it have some small spikes all over the top end?
Y'know, I haven't actually got a good run in yet. Should have more results in a week or two. Gotta remember too that the slip rate on my converter is going to be 20% or more under power, which I am sure kills a bit of hp.
I'm leaving on Thursday for Vegas, but we will be stopping in Reno and then heading down on Friday. Hope to see you there.
FYI I did a couple of fuel only runs out on the street and it seams to run pretty good. I dont have have a dyno close to go tune on anymore so i am hoping that I can just beat me old numbers.
Stomp
