1 ton leaf
Old Aug 1, 2008 | 12:28 PM
bradshaw106's Avatar
1 ton leaf
i have had a set of one ton rear leaf springs given to me. they are only a year old. im thinking of taking out a leaf or two and putting them in my 3/4 ton. the p.o messed with my rear suspension it has six leafs and home made funky lift blocks. i want to get to roughly stock setup in the back so i can install front leveling springs.
what do ya think? take a few leaves out or try to sell them and get different springs
Old Aug 1, 2008 | 12:34 PM
Montana2x2's Avatar
Put the 1 ton springs in as is and get rid of the home made blocks. The ton springs are not much higher than the stock 3/4 ton springs. You will need some bushings for the spring eyes 3/4 OD x 5/8 ID I believe.
Old Aug 1, 2008 | 12:37 PM
i don't want the harsh ride associated with the one ton springs. my truck is a daily driver and i rarely tow. i thinking of putting spring liners to help soften the ride. i was also going to use the factory lift blocks that came with the springs
Old Aug 1, 2008 | 01:05 PM
Montana2x2's Avatar
To be honest I didn't notice too much of a ride difference between the 3/4 and 1 ton in my truck but I expect taking a few leafs out and putting the spring liners in will help some.
Old Aug 1, 2008 | 01:13 PM
bullfrog5.9's Avatar
id put 1 ton spring in the rear and in the front lol
Old Aug 1, 2008 | 04:14 PM
maybe i won't mess with removing leaves and just add spring liners
Old Aug 1, 2008 | 04:36 PM
The two stock options for a W250/350 were 7 leaf and 10 leaf packs. The same lift blocks were used for each. 2wd trucks used the same springs without the blocks, and a 6 leaf pack was available. Overloads were also available but you didn't mention them.
Old Aug 1, 2008 | 07:13 PM
do you think taking out a few leafs of the 10 pack help the ride at all?
Old Aug 1, 2008 | 10:01 PM
Montana2x2's Avatar
Not enough to notice.
Old Aug 2, 2008 | 04:24 AM
If you dropped it back to 6 leafs it would be smoother, but not plush. I wouldn't go less than 6 leaves.
jimbo486
Aug 30, 2010 05:27 AM
97catintenn
May 28, 2010 08:29 PM
Joe T
16
Jun 12, 2007 12:11 AM
dealseeker
24
Dec 18, 2002 10:39 AM
dhe9
Oct 28, 2002 04:57 PM
