$1 Idle adjustment
Old 04-18-2007, 09:59 AM
MikeThomas's Avatar
$1 Idle adjustment
I guess this is a "mommy mommy, look at me" post, but I finally adjusted my idle down after tweeking my pump a bit. I picked up a 10mm wrench for a buck from a local pawn shop, cut the box end off, drilled a 5/16 hole in it, welded it to a 3" long 13mm bolt then SHAZAM, it worked great. I did not want to mangle the nut with the chisel technique so I am pleased. It still takes an extra finger to put it in place but I can adjust it in a few seconds now. PS, I tried to return the remainder of the wrench to Sears...they wouldn't warrantee it .
Old 04-18-2007, 10:12 AM
andyr354's Avatar
I think it was well worth the $1 and a few cents for the bolt.
Old 04-18-2007, 07:58 PM
whereswaldo250's Avatar
Looks like a sweet little tool
Old 04-18-2007, 11:21 PM
Underpsi's Avatar
Wouldn't a crows foot and an extenstion do the same trick?
Old 04-18-2007, 11:45 PM
rbrettctd's Avatar
Yes. Thats how I adjust mine. Easy, but if you dont have one, the $1 wrench is really nice and handy.
Old 04-19-2007, 01:11 AM
MikeThomas's Avatar
I think the crows foot was something like $3 ...this one is at least a boxed wrench to handle the boogered up nut a little better.
Old 04-19-2007, 01:25 AM
rbrettctd's Avatar
Sorry i was thinking wrong. not crowsfoot, I used a wobble joint 10, shorter than a 10mm on a wobble. worked great.
FANZDSLPWR
07-09-2004 06:42 PM
apache
03-30-2004 10:17 PM
Timinva
06-26-2003 09:36 AM
Den052
06-21-2003 12:45 PM
Dusty 96
11-07-2002 03:39 PM
Quick Reply: $1 Idle adjustment
